  2. RF Design
  3. ASSURA RCX FAILS
  • Subscribers 63
  • Views 16347
ASSURA RCX FAILS
Sss19
Sss19 over 11 years ago
This is kind of urgent. I am using IC615 with LFoundry. After successfully running DRC and LVS, RCX fails with the following error. I don't know how to upload any file so I am pasting here.
/usr/local/cadence/installs/ASSURA41/tools/assura/bin/32bit/assura: /usr/local/cadence/installs/ASSURA41/tools/lib/SuSE/libelf.so.1: no version information available (required by /usr/local/cadence/installs/ASSURA41/tools/assura/bin/32bit/assura)
Assura (R) Physical Verification Version av4.1:Production:dfII6.1.5:IC6.1.5.500.17
Release 4.1_USR4_HF21
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av4.1:Production:dfII6.1.5:IC6.1.5.500.17 02/26/2015 11:43 (sjfql220) $
sub-version 4.1_USR4_HF21, integ signature 2015-02-26-1056
run on CadenceLatest from /usr/local/cadence/installs/ASSURA41/tools.lnx86/assura/bin/32bit/assura on Tue May 12 23:58:33 2015
Checking out 1 license for Assura_RCX
Warning: no ?parasiticBlockingDeviceCellsFile match for ind0n27a10g0
Warning: no ?parasiticBlockingDeviceCellsFile match for ind0n56a05g0
Warning: no ?parasiticBlockingDeviceCellsFile match for ind0n66a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind1n20a05g0
Warning: no ?parasiticBlockingDeviceCellsFile match for ind1n30a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind1n70a05g0
Warning: no ?parasiticBlockingDeviceCellsFile match for ind1n90a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind2n00a05g0
Warning: no ?parasiticBlockingDeviceCellsFile match for ind2n20a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind3n30a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind3n60a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind5n20a02g4
Warning: no ?parasiticBlockingDeviceCellsFile match for ind7n40a01g0
Warning: no ?parasiticBlockingDeviceCellsFile match for ind10n0a01g0
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_3_3
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_3_4
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_hs_3
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_ll_3
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_ll_4
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_3i_3
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_3i_4
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_hsi_3
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_hsi_4
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_lli_3
Warning: no ?parasiticBlockingDeviceCellsFile match for nmosrf_lli_4
Warning: no ?parasiticBlockingDeviceCellsFile match for nvarrf_dne
Warning: no ?parasiticBlockingDeviceCellsFile match for nvarrf_dnn
Warning: no ?parasiticBlockingDeviceCellsFile match for nvarrf_dpe
Warning: no ?parasiticBlockingDeviceCellsFile match for nvarrf_sne
Warning: no ?parasiticBlockingDeviceCellsFile match for nvarrf_snn
Warning: no ?parasiticBlockingDeviceCellsFile match for nvarrf_spe
Warning: no ?parasiticBlockingDeviceCellsFile match for pmosrf_3_3
Warning: no ?parasiticBlockingDeviceCellsFile match for pmosrf_3_4
Warning: no ?parasiticBlockingDeviceCellsFile match for pmosrf_hs_3
Warning: no ?parasiticBlockingDeviceCellsFile match for pmosrf_hs_4
Warning: no ?parasiticBlockingDeviceCellsFile match for pmosrf_ll_3
Warning: no ?parasiticBlockingDeviceCellsFile match for pmosrf_ll_4
Warning: no ?parasiticBlockingDeviceCellsFile match for rppolyrf_l
Warning: no ?parasiticBlockingDeviceCellsFile match for cmimrf
Warning: no ?parasiticBlockingDeviceCellsFile match for cmimrf*
Warning: no ?parasiticBlockingDeviceCellsFile match for nldmosrf_5a*
Warning: no ?parasiticBlockingDeviceCellsFile match for pldmosrf_5a*
Warning: no ?parasiticBlockingDeviceCellsFile match for nldmosrf_5b*
Warning: no ?parasiticBlockingDeviceCellsFile match for pldmosrf_5b*
Starting /usr/local/cadence/installs/ASSURA41/tools/assura/bin/rcxToDfII /home/sana/LFoundry/RUNNING/rcx.36.rsf -t -cdslib /home/sana/LFoundry/cds.lib
/usr/local/cadence/installs/ASSURA41/tools/assura/bin/32bit/rcxToDfII: /usr/local/cadence/installs/ASSURA41/tools/lib/SuSE/libelf.so.1: no version information available (required by /usr/local/cadence/installs/ASSURA41/tools/lib/libvirtuos_sh.so)
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.22s.
@(#)$CDS: rcxToDfII version av4.1:Production:dfII6.1.5:IC6.1.5.500.17 02/26/2015 11:46 (sjfql220) $
run on CadenceLatest from /usr/local/cadence/installs/ASSURA41/tools.lnx86/assura/bin/32bit/rcxToDfII on Tue May 12 23:58:35 2015
*WARNING* Technology must be specified!
*WARNING* LIB wed from File /home/sana/LFoundry/cds.lib Line 10 redefines
LIB wed from the same file (defined earlier.)
*WARNING* LIB test from File /home/sana/LFoundry/cds.lib Line 14 redefines
LIB test from the same file (defined earlier.)
*WARNING* LIB test1 from File /home/sana/LFoundry/cds.lib Line 17 redefines
LIB test1 from the same file (defined earlier.)
*WARNING* LIB t1 from File /home/sana/LFoundry/cds.lib Line 18 redefines
LIB t1 from the same file (defined earlier.)
*WARNING* LIB test2 from File /home/sana/LFoundry/cds.lib Line 19 redefines
LIB test2 from the same file (defined earlier.)
*WARNING* The directory: '/home/sana/LFoundry/wed1' does not exist
but was defined in libFile '/home/sana/LFoundry/cds.lib' for Lib 'wed1'.
*WARNING* The directory: '/home/sana/LFoundry/test3' does not exist
but was defined in libFile '/home/sana/LFoundry/cds.lib' for Lib 'test3'.
Finished /usr/local/cadence/installs/ASSURA41/tools/assura/bin/rcxToDfII
Constructing the RCX run script
*** ASSURA capgen VERSION 3.2 Red Hat Linux release 7.2 (Enigma) - (07/07/2010-10:53) ***
* (c) Copyright 2015, Cadence Design Systems, Inc. *
* All rights reserved. *
* This software is the confidential and proprietary information of *
* Cadence Design Systems, Inc. and may not be copied or reproduced *
* in whole or in part onto any medium without Cadence's express *
* prior written consent. Unpublished rights reserved under all *
* copyright laws of the United States. *
* Cadence Design Systems, Inc. *
* 555 River Oaks Parkway *
* San Jose, CA 95134 *
capgen Capgen results will be written to directory: /home/sana/LFoundry/RUNNING/36
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 10 INVALID invalid option 'pro_cont' in EXT_CONT statement
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 11 INVALID invalid option 'pro_cont' in EXT_CONT statement
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 12 INVALID invalid option 'pro_cont' in EXT_CONT statement
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 13 INVALID invalid option 'pro_cont' in EXT_CONT statement
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 14 INVALID invalid option 'pro_cont' in EXT_CONT statement
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 15 INVALID invalid option 'pro_cont' in EXT_CONT statement
*WARNING* at "capgen": file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile, line 16 INVALID invalid option 'pro_cont' in EXT_CONT statement
*ERROR* at "capgen": errors found in -p2lvs file /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile
quitting.
Forking: /usr/local/cadence/installs/ASSURA41/tools/assura/bin/32bit/capgen -techdir /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc -lvs /home/sana/LFoundry/RUNNING/36.xcn -p2lvs /usr/local/cadence/installs/PDK_LF150i_V2_0_0/pv/assura/6metal/qrc/p2lvsfile -sw3d -blocking _ngate_cap_m_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_m_dnw:0.1,STI,DIFF,POLY2 -blocking _pgate_cap_m:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_l_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_l_dnw:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_h_bulk:0.1,STI,DIFF,POLY2 -blocking _ngate_cap_h_dnw:0.1,STI,DIFF,POLY2 -blocking mim1c:0.6,STI,METAL5,METALF -p POLY2,allGate,DIFF -length_units meters -genericMos _nmos_ll_sal1,D,G,S -genericMos _nmos_3_sal,D,G,S -genericMos _nmos_5_sal,D,G,S -genericMos _pmos_ll_sal1,D,G,S -genericMos _pmos_3_sal,D,G,S -genericMos _pmos_5_sal,D,G,S /home/sana/LFoundry/RUNNING/36
*WARNING* Bad return status from RCX script generator. 0x100
Please help me solve the issue.
Thanks and Regards,
Sana Arshad
    Sana, I would suggest you use QRC (from a recent EXT stream) rather than Assura RCX. Assura RCX has been obsolete for many years now, and is only included in the ASSURA stream for legacy reasons. Also, if this is urgent, you should go to customer support for help.
  • Sss19
    Thank you for the reply. I have installed QRC and the av_extracted view gets created easily but then simulating the extracted view in ADE gives the following error.
    Warning from spectre in `pmosrf_hs', during circuit read-in.
    WARNING (SFE-57): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs" 394: Parameter name `m' is reserved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
    Warning from spectre in `nmosrf_hs', during circuit read-in.
    WARNING (SFE-57): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs" 22: Parameter name `m' is reserved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
    Reading link: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading file: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading link: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.vams
    Opening directory input.ahdlSimDB/ (775)
    Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/ (775)
    Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/Linux/ (775)
    Reading file: /home/sana/simulation/Testbench_36/spectre/schematic/netlist/input.ahdlSimDB/bsource.va.bsource_1.ahdlcmi/Linux/obj/optimize/5.0/bsource_1_libahdlcmi.so
    Installed compiled interface for bsource_1.
    Opening directory input.ahdlSimDB//bsource.va.bsource_2.ahdlcmi/ (775)
    Opening directory input.ahdlSimDB//bsource.va.bsource_2.ahdlcmi/Linux/ (775)
    Reading file: /home/sana/simulation/Testbench_36/spectre/schematic/netlist/input.ahdlSimDB/bsource.va.bsource_2.ahdlcmi/Linux/obj/optimize/5.0/bsource_2_libahdlcmi.so
    Installed compiled interface for bsource_2.
    Error found by spectre during hierarchy flattening.
    ERROR (SFE-46): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_resrf.scs" 25: `R01': An instance of `bsource_2' can have at most 3 terminals (but has 4).
    Time for Elaboration: CPU = 200.012 ms, elapsed = 308.748 ms.
    Time accumulated: CPU = 328.02 ms, elapsed = 852.791 ms.
    Peak resident memory used = 36 Mbytes.
    spectre terminated prematurely due to fatal error.
    Andrew, I would appreciate if you can help solve this issue.
    Thanks and Regards,
    Sana
    Hi Sana,
    Without being able to see the netlist and model files, I don't think I can really diagnose the error - so you need to either contact customer support or contact L-foundry. It's possible there's something wrong with the model files or how the devices are being extracted.
    Kind Regards,
