  2. RF Design
  3. Schmitt trigger without hidden states in VerilogA
  • Subscribers 63
  • Views 18398
Clidre
Clidre over 11 years ago
I would like to model with verilog A a fully differential Schmitt trigger, to be used in a pss.
It's a very simple code. At the initial step, the threshold is set to the right value, depending on the inputs. At every subsequent crossing, the threshold is set to a new value, to take into account the hysteresis.
Unfortunately there are hidden states. Below the code:
`include "constants.vams"
`include "disciplines.vams"
module comp_hyst_FullyDiff_NH(outp, outn, p, n);
output outp, outn;
electrical outp, outn;
input p,n;
electrical p,n;
parameter real input_offset=0;
parameter real hyst_offset=0.1;
parameter real trise=10p;
parameter real tfall=10p;
 real voutp, voutn, vthaux;
analog begin
 @(initial_step) begin
    voutp=1.2*((V(p)-V(n))>input_offset);
    voutn=1.2*((V(p)-V(n))<=input_offset);
    vthaux=input_offset+hyst_offset*((V(p)-V(n))<=input_offset)-hyst_offset*((V(p)-V(n))>input_offset);
end
@(cross(V(p)-V(n)-vthaux)) ;
 begin
    voutp=1.2*((V(p)-V(n))>vthaux);
    voutn=1.2*((V(p)-V(n))<=vthaux);
    vthaux=input_offset+hyst_offset*((V(p)-V(n))<=vthaux)-hyst_offset*((V(p)-V(n))>vthaux);
 end
 V(outp) <+ transition(voutp,trise,tfall);
 V(outn) <+ transition(voutn,trise,tfall);
end
endmodule
This module works without the red semicolon, but it has 3 hidden states: voutp, voutn and vthaux. I added the red semicolon, according with the good hint from Andrew here: http://community.cadence.com/cadence_technology_forums/f/33/t/26712 , but the behaviour is different: by adding the red semicolon in my code, it seems the initial step is skipped; moreover vthaux is still hidden.
I would like to keep the behaviuor that i get without the red semicolon and remove all the hidden states. Any suggestion about how to modify my code?
Thanks a lot!
  • Clidre
    UPDATE: I did other simulations and the code I posted  functionally works with the semicolon, but vthaux is still an hidden state, so I still cannot run a pss. I have the following error
    ERROR (SPCRTRF-15177): PSS analysis doesn't support behavioral module components with hidden states found in component 'comp_hyst_FullyDiff_NH'. Skipped.
    /misc/cadence/comp_hyst_FullyDiff_NH/veriloga/veriloga.va, declared in line 22: Hidden state variable: vthaux
    Any idea how to remove the hidden state in vthaux?
    Thanks a lot. Hope you can help me
    vthaux is a hidden state because the expression defining vthaux depends on the value from the previous timestep - so there is some inherent memory of the state which is stored outside of the matrix.
    You'd need to reformulate the model to use some storage such as the "titrating capacitor" approach that Ken Kundert uses in Hidden state in SpectreRF (with the Verilog-A models available too).
    I'm afraid I don't have the bandwidth to rewrite the model for you (I took a quick look to understand the problem, but can't spend the time to rewrite it, unfortunately). Hopefully my pointers in the right direction will be sufficient.
