  2. RF Design
  3. Contents of hbnoise_xf results directory
  • Subscribers 63
  • Views 16500
Michele Ancis
Michele Ancis over 11 years ago
Hi, from within Virtuoso 6.1.6 , MMSIM 13.1 ISR10
I am performing an hbnoise analysis on top of a {single|double}tone HB.
The simulation creates a series of directories under the psf database:
hb_td
hb_fd
hb_fi
hbnoise_xf
hbnoise
I am interested in the results contained in *hbnoise_xf*, as I am assuming that this directory contains the results, frequency by frequency, of the transfer functions from different points/devices in the netlist to the designated output.
Strangely enough, while the other mentioned directories contain results for each and every node in the netlist (I did a "save all" just to see whether this was the issue), the hbnoise_xf directory contains what seems to me to be a /random/ sample of the instances and devices contained in the top level.
There is only a few nodes in this directory. And of course, none of the ones I am interested in :)
I would like to understand why this happens and how can I influence the results reported in this directory.
Thank you in advance,
Michele
  • Michele Ancis
    ...On a second note, it looks like the hbnoise_xf is more concerned with voltage sources present in the schematic, so it is probably not what I am looking for. I think I have found what I was looking for, i.e. "Noise Separation". This creates the kind of results I need.
    Hi Michele,
    The hbnoise_xf database gives the transfer function from each voltage or current source to the specified output - just as xf and pxf would do (for various peculiar reasons there is no separate hbxf analysis - mostly because the analyses are very similar). All "xf" analyses have the benefit of giving you the transfer function from any input to a single output in a single run - so if  you want to look at (say) supply rejection or image rejection they are really useful and much easier than having to keep moving around an "ac" source.
    You can also set the stimuli parameter to "nodes and terminals" in which case it gives you the transfer function from a voltage source in series with each device terminal or a current source onto each node. You have to save "currents" to get the voltage source transfer functions (because "currents" saves the terminal info). Then on the direct plot form you can click on the device terminals or nodes to get the appropriate transfer function (which will be one of voltage gain, current gain, transconductance or transimpedence) depending on whether the input was a voltage or current source and the output was a voltage different or a probed current.
    I just wanted to give the above info for completeness in case anyone else hit this issue.
  • Michele Ancis
    Hi Andrew, thanks for the extra information :)
    I am curious to try the "nodes and terminals" approach, but I cannot find where this /stimuli/ parameter is set. I am referring to hbnoise.
    So if I understand correctly, the "nodes and terminals" would give me the possibility to click on any node, or device terminal, and obtain a transfer function (or a single point, in case of a single point hbnoise evaluation). This, without having to fill my schematic with explicit voltage sources etc...
    Correct? That would be pretty interesting too.
    Michele
    Hi Michele,
    It's on the "Options" form for the hbnoise analysis:
    If in the worst case it's not present, you can type in stimuli=nodes_and_terminals in the additionalParams field (I'm not sure if there are any circumstances when it doesn't appear though).
    Having done this, you'll then get prompted on the direct plot form to click on either a instance terminal or a net (depending on what type of transfer function you're asking to plot). As I said, for instance terminals I had to set on the Save All form that I wanted to save device currents (and useprobes=yes too). It's a bit strange because this is giving you voltage gain (if you have a voltage output in the hbnoise analysis), but it's because it's really giving you the transfer function associated with that terminal, which is a voltage source in series with the terminal to the voltage across the output.
