  2. RF Design
  3. difference between hb_mt_fd and hb_mt_fi
  • Subscribers 63
  • Views 15639
asetji
asetji over 10 years ago
Hi
in the results of harmonic balance simulations, i see two folders hb_mt_fd and hb_mt_fi. Can anyone tell me what is the difference between these two?
BR
alok
    Hi Alok,
    This is covered in my solution on COS. Put simply, the "fi" results are indexed by harmonic, and the "fd" results are indexed by frequency. The "fd" gives you the total output at each frequency, and the x-axis is frequency. If you want to find a value on the "fd" results, you have to use the value() function. The "fi" data shows frequency as the x-axis when plotted, but they are actually indexed by harmonic - so the output for each harmonic (or harmonic combination) is output (this can mean you have different values at the same frequency if you have commensurate frequencies involved). You need to use the harmonic() function to pick out a value if using the "fi" data. This then has the advantage of being able to access data if the harmonics are the same but the frequencies are being swept.
