  2. RF Design
  3. Using noise file to model phase integration in ideal os...
  • Subscribers 63
  • Views 15685
Using noise file to model phase integration in ideal oscillator
apskohli
apskohli over 10 years ago
I created an ideal oscillator model using sources from analogLib. I was able to simulated the model for phase noise (jitter mode).
The phase-noise plot correctly predicts the the 1/(f^2) region as only resistors thermal noise is modeled. On adding a noise file
with 1/f profile I'm still only getting phase noise with 1/(f^2) region, which brings me to my question. Does using a noise file limit
spectreRF to modelling the effect of white noise sources or the 1/(f^3) region can be modeled this way as well? This is important as
we rely heavily on noise file to model system level noise sources and close in phase-noise is important to us.
Aman
  • apskohli
    Hi Andrew, Can you please respond to my query? Thanks, Aman
    Aman,
    I'm not sure - I'd probably need to see the example and see how your ideal oscillator is implemented and where the noise source is.
    If you needed a speedy response - then the best option is to go to customer support (I'm answering these things in my spare time, which is rather limited at the moment).
  • apskohli
    Thanks! Andrew. I'll contact customer support.
