  2. RF Design
  3. Using "winding" in analogLib as a transformer
  • Subscribers 64
  • Views 9887
RFStuff
RFStuff over 10 years ago
Dear All,
I want to use a transformer with turn ratio  and different dot positions the primary and secondary.
xfmr in analoglib doesn't allow this.
I am thinking to use "winding" in analogLib.
First whether it is the right approach ? If so could anybody please tell how to be used.
If not, is there any other way I can change the dot positions in the transformer ?
Kind Regards,
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    Why don't you just use xfmr and swap the connections to one of the two windings?
  • RFStuff
    Dear Frank,
    How the mutual inductance can be set ? Is it the multiplier value ?
    Could you please point to the document which actually explains the elements present in analogLIb of Spectre
  • Frank Wiedmann
    xfmr is an ideal transformer, so there is no mutual inductance, just numbers of turns. You can find the documentation in the "Analog Library Reference" at http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:TechPubDocs;src=pubs;releaseName=;DocumentType=manuals;q=/analoglibref/analoglibrefIC6.1.7/passives.html#1099504.
  • RFStuff
    Dear Frank,
    Thanks a lot !
