  2. RF Design
  3. Problem with Hidden states in Verilog A while running PSS...
  • Subscribers 63
  • Views 6190
Problem with Hidden states in Verilog A while running PSS/PAC...
JRAM
JRAM over 9 years ago
Dear All,
I wrote a code in Verilog A  to generate four different clocks clk1, clk2, clk3 and clk4 from clk, as shown below. These clocks are used for switching in the filter.  While doing PSS/PAC analysis for plotting the magnitude response of filter, its giving an error shown below, Could anybody please tell how can I avoid this. I am a beginner in Verilog A, the code is also posted for the reference.
Jayaram
ERROR In Running PSS/PAC...
Error found by spectre during periodic steady state analysis `pss'.
    ERROR (SPCRTRF-15177): PSS analysis doesn't support behavioral module components with hidden states found in component 'JYR_CLKgen_VerA'.  Skipped.
        /home/jayaram/SCL_JYR_filter/JYR_CLKgen_VerA/veriloga/veriloga.va, declared in line 18: Hidden state variable: count
        /home/jayaram/SCL_JYR_filter/JYR_CLKgen_VerA/veriloga/veriloga.va, declared in line 19: Hidden state variable: vout1
        /home/jayaram/SCL_JYR_filter/JYR_CLKgen_VerA/veriloga/veriloga.va, declared in line 19: Hidden state variable: vout2
        /home/jayaram/SCL_JYR_filter/JYR_CLKgen_VerA/veriloga/veriloga.va, declared in line 19: Hidden state variable: vout3
        /home/jayaram/SCL_JYR_filter/JYR_CLKgen_VerA/veriloga/veriloga.va, declared in line 19: Hidden state variable: vout4
Analysis `pss' was terminated prematurely due to an error.
CODE:
`include "constants.h"
`include "disciplines.h"
module JYR_CLKgen_VerA(vclk, vclk1, vclk2, vclk3, vclk4);
input vclk;
output vclk1, vclk2, vclk3, vclk4;
electrical vclk, vclk1, vclk2, vclk3, vclk4;
parameter real vtrans_clk=0.9;
parameter real voh=1.8;
parameter real vol=0.0;
parameter real tdel = 0 from [0:inf);
parameter real trise = 0.1n from [0:inf);
parameter real tfall = 0.1n  from [0:inf);
 integer count;
  real vout1, vout2, vout3, vout4;
   analog begin
       @(initial_step) begin
            count = 0;
             end
    @ (cross(V(vclk) - vtrans_clk, 1.0)) begin
     if (count == 0) begin
        vout1 = voh;
            vout2 = vol;
         vout3 = vol;
        vout4 = vol;
         end
  else if (count <= 7) begin
            vout1 =vol;
            vout2 = voh;
         vout3 = vol;
        vout4 = vol;
      end
  else if (count <= 20) begin
            vout1 = vol;
            vout2 = vol;
         vout3 = voh;
        vout4 = vol;
      end
  else if (count <= 31) begin
            vout1 = vol;
            vout2 = vol;
         vout3 = vol;
        vout4 = voh;
      end
 if (count<=31)
     count = count+1;
else count = 0;
      end
    V(vclk1) <+ transition(vout1,tdel,trise,tfall);
    V(vclk2) <+ transition(vout2,tdel,trise,tfall);
    V(vclk3) <+ transition(vout3,tdel,trise,tfall);
    V(vclk4) <+ transition(vout4,tdel,trise,tfall);
   end
endmodule
    This is not entirely trivial to avoid because of the fact that you are storing state in the count and vout1->4 variables. I'd advise you to look at this page:
    In particular the Hidden state in SpectreRF application note. I posted the link to the page rather than the document directly so you could also easily find the Verilog-A models that Ken Kundert uses in his app note.
  • JRAM
    Thanks for the reply Andrew, I'll go through the document and Models...
    Jayaram
