  2. RF Design
  3. RF front-end simulation
  • Subscribers 64
  • Views 16237
fmdepassos
fmdepassos over 9 years ago
Dear collegues,
I am trying to simulate an RF front-end (LNA+VCO+MIXER) in order to get performances such as conversion gain, noise figure, etc.
If I simulate only the LNA+MIXER and use a Vsin to emulate the behavior of the VCO I can perform a PSS+PNOISE+PAC and get all the desired performances.
However, If i use the "real" VCO, which is an autonomous circuit, then the PSS does not work correctly:
- If I simulate the whole front-end and give the fundamental frequency, then it does not get the exact VCO frequency, and I cannot get the performances.
- If I simulate the whole front-end and the PSS is enable for autonomous circuits, then it simulates the entire front-end as an oscillator, and I cannot get the performances.
Can anyone help me with this issue?
Best Regards,
Fabio
  • Niraj1717
    Niraj1717 over 8 years ago
    Hello Sir,
    I am trying to simulate a double balanced mixer.But I am unable to understand the simulations to be done i.e pss,pac,pnoise etc.
    Your support would guide me complete my ME project.
    Andrew Beckett over 8 years ago in reply to Niraj1717
    A rather open ended question, but I suggest you look at <SPECTREinstDir>/tools/spectre/examples/SpectreRF_workshop/rfworkshop.tar.Z - unpack this (tar xvfz rfworkshop.tar.Z) and then look at the doc directory - there's a PDF on various analyses for Mixers.
