  2. RF Design
  3. Adding same (fully correlated) Phase-noise to two LO pa...
  • Replies 11
  • Subscribers 64
  • Views 22241
Adding same (fully correlated) Phase-noise to two LO paths
RFStuff
RFStuff over 8 years ago
Dear All,
I have 4 LO paths (LO0, LO90, LO180 and LO270)  with 25% duty cycle clock output wave forms.
These wave forms are almost squarish and captured form another LO generation circuit simulation.
Currently, I using the captured files of the 4-waveforms for PSS/Pnoise simulation of the receiver circuit.
I want to add  phasenoise to the 4 LO paths.  I have a phase-noise profile file.
But, the important thing I want is :- The phasenoise of LO0 and LO180 should be completely co-related and the phasenoise of  LO90 and LO270 should be completely co-related.
How this can be achieved.
Could anybody please help in this regard.
Kind Regards,
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago
    I guess that you could create two correlated noise sources by feeding two controlled sources (like vcvs) with the same noise source.
  • RFStuff
    RFStuff over 8 years ago in reply to Frank Wiedmann
    Hi Frank,
    Thanks for your reply.
    Each LO is given though the port which contains the captured file of the LO waveform.
    The phase noise is added by adding the phasenoise profile file to the PORT.
    So, through VCVS it can not be done.
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago in reply to RFStuff
    How about using a single port together with the ideal_balun component (see also http://www.designers-guide.org/Analysis/diff.pdf) to generate the correlated LO signals?
  • RFStuff
    But then  how I will get LO180 with 180 degree phase shifted.?
    The LO pulses are NOT symmetric rather they are 25% duty-cycle clocks.
    Andrew Beckett over 8 years ago in reply to RFStuff
    Have the noise sources separate from the large signal sources and then add them together (e.g. with the output of each vcvs in series with the large signal pulse source). BTW, the vsource allows noise to be generated as an SSB Phase Noise (this is the "Noise Type" parameter).
  • Frank Wiedmann
    Sorry, I had overlooked this detail. So I'm back to my first proposal: add the noise generated by a vsource with a noisefile by using controlled sources.
    Andrew Beckett over 8 years ago in reply to Frank Wiedmann
    Apologies for my repetition of Frank's suggestion - unfortunately there's a "feature" (well, a bug) of the forums that we've raised with the software provider which happens with Apple Mail (on iPhone and Mac) which some causes email notifications in the same thread to vanish (I know the root cause, but they've not fixed it yet).
  • RFStuff
    RFStuff over 8 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks for your reply. For clarification:-
    What I understand form your suggestions is:- Instead of  adding the phasenoise profile into the large signal vsource, use another vsource with phasenoise profile file added to it.
    I think in that scenarios, the vsource corresponding to the noise-source will have Source Type Setting:- DC, DC Voltage-0, Generate Noise- Yes and Noise File:- <the phasenoise profile file>.
    Then use a vcvs for addition of the large signal Vsource with the noise Vsource.
    But will it perform the same way of adding the the phasenoise profile into the large signal vsource ?
    Kind Regards,
    Yes, it should (as far as I know - I've not done experiments to confirm this though). You should also pick the Noise Type as being "SSB Phase Noise (dBc)" too to make sure the noise is generated correctly.
  • RFStuff
    Dear Andrew,
    I tried. I set Source Type Setting:- DC, DC Voltage-0, Generate Noise- Yes and Noise File:- <the phasenoise profile file>.
    I set the noisetype=SSB Phase Noise (dBc).
    But it is giving error as:-
    Error found by spectre during initial setup.
    ERROR (CMI-2914): V1: To use noisetype=ssbphasenoise feature, the source type should be set to sine type
    ERROR (CMI-2913): V0: At least one frequency in freqvec or in freq and freq2 should be greater than zero for noisetype=ssbphasenoise.
