  2. RF Design
  3. extraction parameters not recognised in hirarchy simula...
  • Subscribers 63
  • Views 16974
extraction parameters not recognised in hirarchy simulation
yefJ
yefJ over 7 years ago
Hello,i have tried to simulate the extraction model of the layout inverter,
i have build a hirarchy and defined the inverter to be the av_extracted file as shown bellow.
However the transient simulation of the test bench doesnt recognise the exctracted capacitors.
The full log txt is attached.
where did i go wrong?
Fullscreen 0654.log.txt Download
System load averages (1min, 5min, 15min) : 13.1 %, 14.8 %, 14.2 %
Simulating `input.scs' on micron.eng.tau.ac.il at 10:27:07 PM, Tue Jul 2, 2019 (process id: 14217).
Current working directory: /data.cc/data/a/home/cc/students/enginer/yafimv/simulation/test_inv/spectre/config/netlist
Command line:
    /eda_disk/cadence/tools/MMSIM/151/tools/bin/spectre -64 input.scs  \
        +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre0_26098_4 -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 14217
Loading /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
Loading /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/simulation/test_inv/spectre/config/netlist/input.scs
Reading file:  /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/spectre/etc/configs/spectre.cfg
Reading file:  /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/spectre/etc/configs/mapsubckt.cfg
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_mos.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_diode.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_bipolar.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_mimcap.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_moscap.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_resistor.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_inductor.scs
Reading file:  /data.cc/data/a/home/cc/students/enginer/yafimv/gpdk045_v_5_0/models/spectre/gpdk045_soa.scs
Time for NDB Parsing: CPU = 720.89 ms, elapsed = 872.811 ms.
Time accumulated: CPU = 753.884 ms, elapsed = 872.823 ms.
Peak resident memory used = 55.6 Mbytes.
The CPU load for active processors is :
        Spectre  0 (83.7 %)      1 (2.3 %)       4 (9.3 %)       5 (4.5 %)
                 6 (4.5 %)       7 (100.0 %)
        Other
Error found by spectre in `inv_scm', during circuit read-in.
    ERROR (SFE-23): "input.scs" 16: The instance `c1' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 17: The instance `c2' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 18: The instance `c3' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 19: The instance `c4' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 20: The instance `c5' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 21: The instance `c6' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 22: The instance `c7' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 23: The instance `c8' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 24: The instance `c9' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
    ERROR (SFE-23): "input.scs" 25: The instance `c10' is referencing an undefined model or subcircuit, `cmodel'. Either include the file containing the definition of `cmodel', or define `cmodel' before running the simulation.
Reading link:  /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading file:  /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Reading link:  /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/spectre/etc/ahdl/constants.h
Reading file:  /eda_disk/cadence/tools/MMSIM/151/tools.lnx86/spectre/etc/ahdl/constants.vams
Opening directory input.ahdlSimDB/ (775)
Opening directory input.ahdlSimDB//bsource_08102a.va.bsource_08102a.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource_08102a.va.bsource_08102a.ahdlcmi/Linux-64/ (775)
Compiling ahdlcmi module library.
Finished compilation in 1.97 s (elapsed).
Installed compiled interface for bsource_08102a.
Time for Elaboration: CPU = 111.983 ms, elapsed = 2.16529 s.
Time accumulated: CPU = 866.867 ms, elapsed = 3.03847 s.
Peak resident memory used = 70.5 Mbytes.
Aggregate audit (10:27:10 PM, Tue Jul 2, 2019):
Time used: CPU = 869 ms, elapsed = 3.04 s, util. = 28.6%.
Time spent in licensing: elapsed = 15.6 ms.
Peak memory used = 70.7 Mbytes.
Simulation started at: 10:27:07 PM, Tue Jul 2, 2019, ended at: 10:27:10 PM, Tue Jul 2, 2019, with elapsed time (wall clock): 3.04 s.
spectre completes with 10 errors, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
    On the QRC extraction form, on the Netlisting tab, ensure that the Parasitic Capacitor Models and Parasitic Resistor Models are both set to either Include as Comment or Do not Include. You must have them set to Include Model. You'll need to re-run the extraction to create the extracted view again.
    This is covered in spectre simulation with av_extracted view gives error about undefined model cmodel.
  • yefJ
    yefJ over 7 years ago in reply to Andrew Beckett
    Hello Andrew, this is my QRC  extraction window, i have signed the extaction to be RC type but there is no include model option in this window.
    Andrew Beckett over 7 years ago in reply to yefJ
    Did you read what I said earlier? I said “on the Netlisting tab”. Please look there
