  2. RF Design
  3. modulated PAC analysis
  • Subscribers 63
  • Views 16582
StanleyChe
StanleyChe over 7 years ago
Hi, I am currently using Virtuoso IC6.1.6 and running SpectreRF simulation in MMSIM151. I am attempting to run a modulated PAC simulation. Please see my setup below:
One thing I do not know is the meaning of "Output Upper Sideband". Also, if I switch the "Input Type" from SSB to "SSB/AM/PM", "Output Upper Sideband" changes to "Input Modulated Harmonic" as seen below:
My understanding in this case is that it is supposed to set the input frequency range (only one can be chosen). But isn't this already set from the Relative harmonic and frequency sweep range specification?
I have found very scarce documentation on this field. Any help is appreciated.
regards,
SC
    Please contact customer support.
