  2. RF Design
  3. passive mixer-first receiver IIP3 simulation: IM3 curve...
  • Subscribers 63
  • Views 5812
passive mixer-first receiver IIP3 simulation: IM3 curve not 3dB/dB
Joy wang
Joy wang over 7 years ago
I design a common passive mixer-first receiver(passive mixer +TIA) in TSMC65LP  CMOS process. In the test bench, I drive the receiver with a port , then a idea_bulun , then an ac coupling capacitor connect to the receiver. I use HB method to simulate the IIP3 of the receiver(Lab 10: IP3 Calculation (hb with Three Tones)  ). I have two questions:
1. why the IM3 curve is not 3dB/dB ?
2. when I set different "number of harmonics"(from auto 3 3 to 3 2 2), the IM3 curve change greatly, but the slope is still  non-monotonic.
Why is the difference so significant and how can I simulate the correct curve ?
Thank you!
    I'm not sure reducing the number of harmonics is very likely to help, but there are known challenges with simulating IP3 with passive mixers due to limitations in the bsim4 and bsim3v3 models. See this article: Difficulties simulating IP3 on a switched-FET mixer (which references a paper from IBM describing the problem too). It's related to the fact that the derivatives in the model are not smooth at Vds=0 - but the paper includes more details.
  • Joy wang
    Joy wang over 7 years ago in reply to Andrew Beckett
    Hi Andrew:
    thank you. It seems that I don't have the access to support.cadence.com.
    Andrew Beckett over 7 years ago in reply to Joy wang
    Here's a link to the IBM paper: https://briefs.techconnect.org/papers/linfet-a-bsim-class-fet-model-with-smooth-derivatives-at-vds0/
  • Joy wang
    Thanks again Andrew!
