  2. RF Design
  3. Construct Explorer Expression to evaluate Y over reduced...
  • Subscribers 63
  • Views 15841
Construct Explorer Expression to evaluate Y over reduced X range
mposey
mposey over 6 years ago
I am seeking for some help constructing expressions in ADE Explorer. Specifically, I am trying to set up output expressions to calculate specs so that they only apply over a reduced / specific X range so that I can properly construct my spec items where the spec target is dependent on what X range I am looking at. There are a number of cases where this might come up but for me the most common sort of example for me would be gain vs frequency where I might have a number of specifications of gain depending on whether this inband or out of band and different requirements at different out of band frequencies. I'd like to just run a single sp sim over a broad range of frequencies then the break out the specs rather than running a large number of sp sims This is Virtuoso IC6.1.7
Thanks and Regards,
Matt
    Matt,
    Use the clip function to return a waveform between two x points.
  • mposey
    mposey over 6 years ago in reply to Andrew Beckett
    Perfect thank you. That function does what I need.
    Matt
