  2. RF Design
  3. Can't compile ahdlcmi library
  • Subscribers 63
  • Views 2312
HaolinCong
HaolinCong over 6 years ago
I am trying to use veriloga module in my simulation. But I met an error message ::
Compiling ahdlcmi module library.
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//3140_Cadence_workarea_testLib_and_gate_veriloga_veriloga.va.and_gate.ahdlcmi/Linux-64/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. Otherwise, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (SFE-91): Error when elaborating the instance and_gate. Simulation should be terminated.
Then I checked the ahdlcmi.out file and find it shows::
ld: cannot find -lc
collect2: ld returned 1 exit status
gnumake: *** [obj/optimize/5.0/and_gate_libahdlcmi.so] Error 1
But I have no idea what is that.
Thank you very much if anyone can help me with this. ~~
  • HaolinCong
    I can't upload the full content of ahdlcmi.out file because the forum will flag it as spam. Please let me know if you need any more information.
    Thank you very much,
    Andrew Beckett over 6 years ago in reply to HaolinCong
    Did you contact customer support as was suggested in the error message?
