  2. RF Design
  3. K Stability Factor Simulation Results Do not show up
  • Replies 14
  • Subscribers 63
  • Views 25658
Mehdi Nasr
Mehdi Nasr over 6 years ago
I have designed an LNA and am going to check the k Stability factor. When I run the s-parameters I plot the k-stability factor, but nothing shows up and the screen is black and nothing is there. So, any suggestion how can I fix this issue?
Mehdi
    Andrew Beckett over 6 years ago +1
    Hi Medhi, You'll need to provide some more information, because I just did this and it worked fine - and I'm not aware of this being a recently reported issue. So please can you answer these questions…
    Hi Medhi,
    You'll need to provide some more information, because I just did this and it worked fine - and I'm not aware of this being a recently reported issue. So please can you answer these questions:
    1. Which IC subversion are you using? This is in Help->About (please give the full number, not just the first part)
    2. Which spectre version are you using (this will appear at the top of the spectre.out log file in ADE)? Assuming you're using spectre, that is...
    3. Which ADE flavour are you using? ADE L, XL, Explorer or Assembler? Or if not ADE, how are you running the simulation?
    4. How are  you plotting the "k-stability factor" - explain precisely how you are doing this
    5. Please copy and paste the analysis statements from the input.scs file in ADE (the bottom part of the input.scs), particularly the "sp" analysis lines.
    6. Are there any errors that appear in the CIW when you do this?
  • Mehdi Nasr
    Mehdi Nasr over 6 years ago in reply to Andrew Beckett
    Which IC subversion are you using? This is in Help->About (please give the full number, not just the first part) IC6.1.7-64b.500.18
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 15.1.0.803.isr18 64bit -- 21 Jun 2017
    Copyright (C) 1989-2017 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: mehdina94rm Host: amml.ece.neu.edu HostID: A81673C PID: 248590
    Memory available: 82.7415 GB physical: 133.5396 GB
    Linux : CentOS Linux release 7.5.1804 (Core)
    CPU Type: Intel(R) Xeon(R) Gold 6136 CPU @ 3.00GHz
    Socket: Processors [Frequency] (Hyperthreaded Processor)
    0: 0 [1307.2] ( 12 ), 1 [1199.9] ( 13 ), 2 [1200.6] ( 14 )
    3 [1199.9] ( 15 ), 4 [1199.9] ( 16 ), 5 [1199.9] ( 17 )
    6 [1209.6] ( 18 ), 7 [1199.9] ( 19 ), 8 [3599.9] ( 20 )
    9 [1199.9] ( 21 ), 10 [1200.1] ( 22 ), 11 [1200.1] ( 23 )
    System load averages (1min, 5min, 15min) : 5.0 %, 5.7 %, 5.9 %
    Hyperthreading is enabled
    Simulating `input.scs' on amml.ece.neu.edu at 4:15:16 PM, Mon Nov 4, 2019 (process id: 248590).
    Current working directory: /ECEnet/home/student/mehdina94rm/Sim/LNA_diff_matching_finalized_tb/spectre/config/netlist
    Command line:
    /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools/bin/spectre \
    -64 input.scs +escchars +log ../psf/spectre.out -format psfxl \
    -raw ../psf +lqtimeout 900 -maxw 5 -maxn 5
    Loading /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Time for NDB Parsing: CPU = 454.093 ms, elapsed = 1.14059 s.
    Time accumulated: CPU = 492.094 ms, elapsed = 1.1406 s.
    Peak resident memory used = 53.5 Mbytes.
    The CPU load for active processors is :
    Spectre 0 (8.8 %) 1 (6.1 %) 2 (23.5 %) 3 (15.9 %)
    6 (16.1 %) 7 (12.4 %) 8 (100.0 %) 9 (4.5 %)
    11 (12.9 %) 13 (1.7 %) 16 (1.8 %) 21 (2.7 %)
    22 (2.7 %)
    Other
    Reading link: /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading file: /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading link: /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file: /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/constants.vams
    Time for Elaboration: CPU = 152.351 ms, elapsed = 159.82 ms.
    Time accumulated: CPU = 644.588 ms, elapsed = 1.30056 s.
    Peak resident memory used = 81.9 Mbytes.
    Time for EDB Visiting: CPU = 90.327 ms, elapsed = 90.5421 ms.
    Time accumulated: CPU = 735.056 ms, elapsed = 1.39124 s.
    Peak resident memory used = 97 Mbytes.
    Notice from spectre during topology check.
    Only one connection to the following 56 nodes:
    I21.M5|avC2
    I21.M5|avC1
    I21.M7|avC2
    I21.M7|avC1
    I21.M17|avC2
    Further occurrences of this notice will be suppressed.
    No DC path from node `I21.M5|avC2' to ground, Gmin installed to provide path.
    No DC path from node `I21.M5|avC1' to ground, Gmin installed to provide path.
    No DC path from node `I21.M7|avC2' to ground, Gmin installed to provide path.
    No DC path from node `I21.M7|avC1' to ground, Gmin installed to provide path.
    No DC path from node `I21.M17|avC2' to ground, Gmin installed to provide path.
    Global user options:
    reltol = 1e-06
    vabstol = 1e-08
    iabstol = 1e-13
    temp = 27
    homotopy = 7
    limit = delta
    compatible = spice2
    gmin = 1e-12
    rforce = 1
    maxnotes = 5
    maxwarns = 5
    digits = 5
    cols = 80
    pivrel = 0.001
    sensfile = ../psf/sens.output
    checklimitdest = psf
    save = allpub
    tnom = 27
    scalem = 1
    scale = 1
    Scoped user options:
    Circuit inventory:
    nodes 10869
    bsim3v3 172
    capacitor 3468
    diode 472
    inductor 20
    isource 2
    port 3
    resistor 17819
    transformer 2
    vcvs 2
    vsource 3
    Analysis and control statement inventory:
    info 6
    sp 1
    Output statements:
    .probe 0
    .measure 0
    save 0
    Notice from spectre.
    54 notices suppressed.
    Time for parsing: CPU = 33.381 ms, elapsed = 36.0088 ms.
    Time accumulated: CPU = 768.582 ms, elapsed = 1.42739 s.
    Peak resident memory used = 104 Mbytes.
    Pre-Simulation Summary
    Warning from spectre.
    WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
    S-Parameter Analysis `sp': freq = (2 GHz -> 3 GHz)
    Notice from spectre during DC analysis, during SP analysis `sp'.
    GminDC = 1 pS is large enough to noticeably affect the DC solution.
    dV(I21.I9|M2_10__rcx.b1d) = 14.1994 nV
    Use the `gmin_check' option to eliminate or expand this report.
    DC simulation time: CPU = 82.559 ms, elapsed = 82.7818 ms.
    sp: freq = 2.023 GHz (2.84 %), step = 4.653 MHz (568 m%)
    sp: freq = 2.992 GHz (99.4 %), step = 6.882 MHz (568 m%)
    sp: freq = 3 GHz (100 %), step = 7.529 MHz (568 m%)
    Accumulated DC solution time = 80 ms.
    Intrinsic sp analysis time = 820 ms.
    Total time required for sp analysis `sp': CPU = 2.88472 s, elapsed = 3.30678 s.
    Time accumulated: CPU = 3.69166 s, elapsed = 5.28976 s.
    Peak resident memory used = 131 Mbytes.
    modelParameter: writing model parameter values to rawfile.
    Opening the PSF file ../psf/modelParameter.info ...
    element: writing instance parameter values to rawfile.
    Opening the PSF file ../psf/element.info ...
    outputParameter: writing output parameter values to rawfile.
    Opening the PSF file ../psf/outputParameter.info ...
    designParamVals: writing netlist parameters to rawfile.
    Opening the PSFASCII file ../psf/designParamVals.info ...
    primitives: writing primitives to rawfile.
    Opening the PSFASCII file ../psf/primitives.info.primitives ...
    subckts: writing subcircuits to rawfile.
    Opening the PSFASCII file ../psf/subckts.info.subckts ...
    Aggregate audit (4:15:21 PM, Mon Nov 4, 2019):
    Time used: CPU = 4.07 s, elapsed = 5.78 s, util. = 70.4%.
    Time spent in licensing: elapsed = 34.5 ms.
    Peak memory used = 141 Mbytes.
    Simulation started at: 4:15:16 PM, Mon Nov 4, 2019, ended at: 4:15:21 PM, Mon Nov 4, 2019, with elapsed time (wall clock): 5.78 s.
    spectre completes with 0 errors, 1 warning, and 7 notices
    Which ADE flavour are you using? ADE L, XL, Explorer or Assembler? Or if not ADE, how are you running the simulation? ADE L
    How are you plotting the "k-stability factor" - explain precisely how you are doing this. Results --> Direct Plot --> Main Form --> sp --> Kf --> plot
    ps=0.7u*2+(700.0n) nrd=0.3u/(700.0n) nrs=0.3u/(700.0n) \
    par1=((1)*(1))
    I10 (net032 vss) isource dc=500u type=dc
    I5 (net31 vss) isource dc=500u type=dc
    I29 (net13 vss net18 net14) ideal_balun
    PORT3 (LNA vss) port r=50 type=dc
    PORT4 (out vss) port r=50 num=2 type=dc
    E0 (LNA vss RFout\- RFout\+) vcvs gain=1
    E2 (out vss RFout\- RFout\+) vcvs gain=1
    simulatorOptions options reltol=1e-6 vabstol=1e-8 iabstol=1e-13 temp=27 \
    tnom=27 homotopy=all limit=delta scalem=1.0 scale=1.0 \
    compatible=spice2 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 digits=5 \
    cols=80 pivrel=1e-3 sensfile="../psf/sens.output" checklimitdest=psf
    sp sp ports=[PORT1 PORT3] start=2G stop=3G dec=1000 donoise=yes \
    oprobe=PORT3 iprobe=PORT1 annotate=status
    saveOptions options save=allpu
    Are there any errors that appear in the CIW when you do this? No errors.
  • Tawna
    Tawna over 6 years ago in reply to Mehdi Nasr
    1. You are using an extremely outdated version of Spectre.  (15.1).   The latest version is 19.1.  You should upgrade to at least 18.1
    2. You have two ports (PORT3 and PORT4) in your netlist.
    In your sp statement, you list a port that is not in your netlist.   Where is PORT1?:
    Best regards,
    Tawna
    Andrew Beckett over 6 years ago in reply to Tawna
    Tawna,
    The missing port is probably just because this is a snippet of the netlist; if the port was really missing, the sp analysis would fail (I checked).
    Mehdi,
    I ran with the exact same version of MMSIM and IC that you are (Tawna's right, the MMSIM version is old, although the hot fix you're using is less than 2.5 years old, compared with the IC version which is about 1.5 years old - so compared with much that we see here, it's not that bad...). It works fine for me - I even set up the sp analysis the same as you did (same start and stop frequencies, turning on noise, and so on).
    By the way, your reltol/vabstol/iabstol are way too tight. You really should not need reltol of 1e-6 except in very rare situations, and even then only for transient simulations where you need very high dynamic range (typically you'd have to be doing an FFT of the results, and even then you'd need to ensure that it's not your measurement accuracy that is wrong). This is a good way of unnecessarily slowing down the simulations for little advantage.
    However, that's unlikely to be the issue here. The simulation ran in a few seconds, so that's more of a point for future reference.
    Can you try pasting this expression into the calculator and then plotting that to see if this works?
    kf(sp(1 1 ?result "sp") sp(1 2 ?result "sp") sp(2 1 ?result "sp") sp(2 2 ?result "sp"))
  • Mehdi Nasr
    Andrew and Tawana,
    Thanks for your comments. I have checked with school and they will upgrade it. But I am not sure if thats the problems since I was previously running it even with the older cadence version.
    Regarding the missing Port, I have to mention that I have a couple of ports in other parts of the circuit but not used in this simulation. So it will not be an issue since the SP analysis is running and I can get the S parameters without any issue. The only issue is the result of Kf.
    I have checked the equation and that is exactly the same as what you mentioned above, BTW I copied yours into my calculation and the result is the same and nothing shows up.
    Andrew Beckett over 6 years ago in reply to Mehdi Nasr
    Can you plot anything else from the Direct Plot form for the sp analysis? For example, plotting s11 or s22, or any of the other metrics? Is it just Kf that is the problem?
  • Mehdi Nasr
    Andrew,
    I can plot S11, S21, S12, S22, NF. But I cannot plot  Kf and B1f or even Z parameters.
  • Mehdi Nasr
    Mehdi Nasr over 6 years ago in reply to Mehdi Nasr
    Here is the error that I get when I plot z-parameters:
    ERROR (WIA-1006): Unable to plot expression <zpm('sp 1 1)>
    because it does not evaluate to an object that can be plotted, like a waveform or
    parametric wave. See the Visualization & Analysis Tool documentation for information
    about the types of objects that can be plotted in Visualization & Analysis Tool. Only
    the expressions that evaluate to those objects can be plotted.
    *Warning* Wave1 is not a waveform object that can be displayed and
    will be DELETED automatically.
    Can you do the following tests in the CIW after running the simulation and trying to plot in the direct plot form:
    outputs(?result 'sp ?map nil)
    zpm('sp 1 1)
    and paste here exactly what it shows in the CIW - the pasted commands and output/errors between them. For me it shows:
    ("s11" "s21" "s12" "s22" "cy11"
    "cy21" "cy12" "cy22"
    zpm('sp 1 1)
    srrWave:0x32b12020
    srrWave:0x32b12190
  • Mehdi Nasr
    Here is what I got:
    zpm('sp 1 1)
    ("s11" "s21" "s12" "s22")
    nil
    srrWave:0x30bd7420
