  2. RF Design
  3. ruler measurment which sums all sections passed at once
  • Subscribers 63
  • Views 16839
robert 21
robert 21 over 6 years ago
Hello, i am trying to calculate the total perimeter of the inductor.by pressing K i managed only to see the length of separate sections .
Is there a way to see the total perimeter of the whole shape ?
Thanks.
    Your ruler appears to be along the centre line, not the perimeter. If you want to use a ruler, start drawing the ruler and then hit F3 and change the Segment Mode to "Multiple" - it will give you the total across all segments.
    You can also use Options->Dynamic Display (turn on Info Balloon) and it will show the total length of a connected set of path segments (such as above) if you hover over the shapes. If you really want the perimeter, without writing some code (or drawing a ruler) you could select the pathSeg, Edit->Convert->To Polygon, Edit->Basic->Merge, and then hover over the polygon (with info balloons on) and it will show the perimeter. You can then undo twice to get back to where you were...
  • robert 21
    robert 21 over 6 years ago in reply to Andrew Beckett
    Hello Andrew,It Worked.
    Thank You very much  :-)
