  2. RF Design
  3. zpm can't be evaluated
  • Subscribers 63
  • Views 7593
amitG22
amitG22 over 6 years ago
Virtuoso Version -- IC6.1.7-64b.500.23
Cadence Spectre Version -- 17.10.515
I have a very simple circuit. Please find attached. It is basically a resistor across a port. I run a S-param simulation and can plot the S-params, but unfortunately not the Z-param or Y-param.
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/33/Capture_5F00_Sch.JPG
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/33/Capture_5F00_Error.JPG
Can anyone point me in the correct direction to sort out this problem? The zpm does work in another design environment, but not in the new design environment (a new project). The virtuoso and the cadence-spectre versions match in both the project environments. I am at a loss at what to look for.
    The pictures are rather hard to see, but the problem is that somebody in your environment has done:
    setVarWriteProtect('name)
    and that is killing the code. It appears to me that the problem only occurs if you have zpm('sp 1 1) in the ADE outputs.
    I suspect you'd also get an error if in the CIW you do:
    foreach(name list(1 2) println(name))
    You need to find wherever this setVarWriteProtect('name) is being performed and remove it. Write protecting a variable with a simple name like this is just asking for trouble.
    Andrew Beckett over 6 years ago in reply to Andrew Beckett
    I should point out that if I enter zpm('sp 1 1) in the calculator and try to plot from there, it worked even with this variable write protected. Also if I used the direct plot form and hit the ZP button.
  • amitG22
    amitG22 over 6 years ago in reply to Andrew Beckett
    Thanks for replying back.
    I have tried using zpm in the calculator as well as using it from the "Direct Form" option. It still didnt work.
    Andrew Beckett over 6 years ago in reply to amitG22
    It's possible that I got lucky in the version I was using - I was not proposing the calculator or direct plot as a solution, . You need to remove this setVarWriteProtect, as it's likely to break all sorts of things.
    Maybe try running "virtuoso -nocdsinit" and see if that fixes it? It may give you somewhere to start looking if this is something loaded from a .cdsinit somewhere. There should not be an error about "name" being write protected unless somebody has explicitly done this somewhere.
  • amitG22
    Thanks. I will get in touch with the responsible person on Monday and try the "nocdsinit" solution too. I will provide an update afterwards.
    Thanks a lot.
    Amit
  • amitG22
    #### UPDATE ####
    Just updating this thread with the current status.
    You were right about the solution. Our CAD team was able to find the root cause to an internal tool loaded in the cdsinit file. Removing that tool, solves our issue with the Z/Y parameters.
    Thanks a lot for your help.
    Amit
