  2. RF Design
  3. Kf parameter testing in spectre under non standart cond...
  • Subscribers 63
  • Views 19188
Kf parameter testing in spectre under non standart conditions
robert 21
robert 21 over 6 years ago
Hello, i need to test the  parameter Kf under some conditions in subthreshold.i cannot just plot the OP param,becasue i need to derive it under certain conditions.
Spectre(of Cadence) like BSIM(of Berkley) has developed a method for deriving each parameter in their model.
Is there a way to help me with such manual where i can test in cadence virtuoso the Kf parameter shown in the formula bellow?
Thanks.
    I do love it how you've posted an equation with absolutely no context. It would probably increase the likelihood of an answer if you can ask a decent question in the first place with sufficient information that somebody can stand a chance of answering it.
    Luckily I recognised it as likely to be related to flicker noise modeling, and it corresponds to equation 21-142 in the BSIM4 chapter of the Spectre Circuit Simulator Components and Device Models Reference assuming that AF=2 (the default value is 1), and EF=1 (that's the default). The parameters AF, EF, and KF are model parameters for various device models (including BSIM4). From "spectre -h bsim4" you'll see:
    438 af=1.0 Flicker noise exponent.
    439 ef=1.0 Flicker noise frequency exponent.
    440 kf=0.0 A^(2-EF)*s^(1-EF)*F   Flicker noise coefficient.
    Spectre will output any model parameters into the models database - or you can just look in the model definition to see the parameters - they are not computed. So it's nothing to do with the region the device is operating in.
  • robert 21
    robert 21 over 6 years ago in reply to Andrew Beckett
    Thanks.
