  2. RF Design
  3. Three tones IIP3 simulation
  • Subscribers 63
  • Views 20338
EiRFIC
EiRFIC over 6 years ago
Hi All,
I saw the cadence tutorial on measuring IIP3 with 3 tones test (Lets say I have a mixer in the test so two tones are entered in the RF port and one is the LO).
Now, I would like to verify if my receiver meets the bluetooth standard. In the standard it says to enter a signal at -64dBm and two additional signals (interference)
at -39dBm each which placed one k (lets say k equals to one for the example) channels apart and the other 2k channels apart (so 3 signals enter the RF port). These signals cause an intermodulation product to fall
at the frequency of the desired signal. I would like to measure the IIP3 in this case.
Now, I need to enter 4 tones and the IIP3 is measured (based on cadence tutorial) using sweep in the hb.
I do not want to sweep power since I need to enter exact power. I tried to use multi sinusoidal option in the port with exact power but it does not work.
How in general am I be able to check communication standard in this way using virtuoso and measure IIP3?
Can someone please help me?
Thanks in advance!
  • Tawna
    Tawna over 6 years ago
    Hi Eric,
    • Which tutorial?  Please post the exact name or give the link.
    • Why do you want to use three large tones?  If this is not a large signal IP3 (like a transmit mixer), you can use rapidIP3 which is a LOT faster.
    • What specifically are you simulating?
    • If you are trying to look at Wireless Communication standards, you may want to look at our Wireless workshop:  SpectreRF APS Workshop for Wireless Simulation
    • Please check out SpectreRF AppNotes and Tutorials - One of our best kept secrets! (Dec 30 2019)
    Article (20463330)
    Title: SpectreRF AppNotes and Tutorials - One of our best kept secrets!
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000007MVj5EAG&pageName=ArticleContent
    best regards,
    Tawna
  • EiRFIC
    EiRFIC over 6 years ago in reply to Tawna
    Hi Tawna,
    1. I am talking about the mixer tutorial (do not have a link).
    2 and 3. I explained that I am trying to simulate IIP3 of a receiver to see if it meets the bluetooth standard (but not 3 tones test but actually 4). I mentioned it in my question (if something is not clear please let me know
    and I will rephrase it).
    4. Cadence Wireless Communication Standards do not help. They do not deal with what I am looking.
  • Tawna
    Tawna over 6 years ago in reply to EiRFIC
    Hi Eric,
    I'm really sorry I don't have time to delve into this.  (I have my day job that is extremely busy right now).  I suggest that you file a Case with Customer Support (https://support.cadence.com ).  That way, an AE can look at this right away for you.   I've not done a "4 tone IP3" measurement.  Since this is a receiver and not a transmitter, I'd be inclined to look at hbac/rapidIP3, rather than a 3 (or 4) large tone hb.
    Things that will help the AE are:  software version you are using (spectre and virtuoso), the 4 frequencies in the circuit, that this is a receiver.   Also if you have a technical paper describing the 4 tone measurement, that would be extremely helpful.  I admit - I could be suffering from a "severe lack of caffeine" and simply missing the obvious here.
    best regards,
    Tawna
