  2. RF Design
  3. extracting s2p file
  • Replies 7
  • Subscribers 63
  • Views 30920
extracting s2p file
robert 21
robert 21 over 6 years ago
Hello, i managed to extract my S-param data into vcsv file,however i need a standart S2P file
i have this table displayed, as shown bellow.
is there a way to extract s2p file in cadence virtuoso?
Thanks.
  • Tawna
    Tawna over 6 years ago
    Hi Robert21,
    What is your end goal?   Why are you putting your S-param data into a vcvs file?
    Are you trying to get s-parameter data from a Spectre simulation?   If so, run an sp analysis.  Before launching the simulation, open the s-parameter options form.  In the Output section, enter the filename for the sp file to be generated.  e.g. myfilter.s2p.   You can specify touchstone, touchstone2, etc. format.   When running the sp simulation, be sure to start low in frequency (e.g. 1 Hz) and go high enough in frequency (I recommend 3X higher than the highest harmonic of interest).   See the article on support.cadence.com "7 Habits of Highly Successful S-Parameters"
    best regards,
    Tawna
    Andrew Beckett over 6 years ago in reply to Tawna
    The same question also came up less than two weeks ago in this post.
  • robert 21
    robert 21 over 6 years ago in reply to Andrew Beckett
    Hello Andrew, I have created a touchstone file by option as shown bellow.(i have renamed it in txt so i could upload it here) but Matlab is not recocnising it. How can i make a touchstone S2p file so Matlab will recognise it?
    Thanks.
    S = sparameters('touchstone_file');
    disp(S)
    Fullscreen touchstone_file.txt Download
    ! Touchstone Ver. 1.0
    ! Number of ports is 2
    # Hz	S	RI	R	33.755800	50.000000
    ! SCATTERING PARAMETERS  :
    5.00000000e+09      0.9998370462737904   0.01561915647365997    -0.1019809531889976  0.004779853015226476   3.057239895107492e-05  0.001938201498904779     0.8242296392549995   -0.0383190935138942
    5.20000000e+09      0.9998497256974158   0.01455847058550708     -0.101951792786102  0.005056455838290084   3.47586563089242e-05   0.00201526932422235     0.8240575409954747   -0.0398355592187962
    5.40000000e+09      0.9998603067266405   0.01355985421811079    -0.1019268863159635  0.005330061805777769   3.910823878138454e-05  0.002092394159076744     0.8238788793022065  -0.04135017501904945
    5.60000000e+09      0.9998690612280682   0.01261650200788977    -0.1019054325787475  0.005601013170019022   4.362145236270438e-05  0.002169569281036344     0.8236936931297953  -0.04286288063602711
    5.80000000e+09      0.9998762140838179   0.01172257408596655    -0.1018867786205584  0.005869601939464925   4.829853707628607e-05  0.002246788806075985     0.8235020222150982  -0.04437361712844012
    6.00000000e+09      0.9998819526463931   0.01087302974962978    -0.1018703887369651  0.006136078784211563   5.313967958185998e-05  0.002324047545317055     0.8233039070437083  -0.04588232689115371
    6.20000000e+09      0.9998864340379372    0.0100634945449708    -0.1018558206894649  0.006400660093289565   5.814502281462316e-05  0.002401340890319995     0.8230993888117761  -0.04738895365434533
    6.40000000e+09      0.9998897908395908  0.009290153150346869    -0.1018427072915015   0.00666353361911674   6.331467341971952e-05  0.002478664720476263     0.8228885093845819  -0.04889344248237476
    6.60000000e+09      0.9998921355655948  0.008549662376414413    -0.1018307420322601  0.006924863030553965   6.864870753238419e-05  0.002556015327668843     0.8226713112529609  -0.05039573977192442
    6.80000000e+09      0.9998935642108666  0.007839079991248998    -0.1018196677653324  0.007184791614663727   7.414717530493347e-05    0.0026333893545457     0.8224478374883157  -0.05189579324909063
    7.00000000e+09      0.9998941590856577  0.007155806098073425    -0.1018092677441661  0.007443445308463445   7.981010447626245e-05  0.002710783743612804     0.8222181316968168  -0.05339355196521067
    7.20000000e+09      0.9998939910968913  0.006497534546979655    -0.1017993584691587  0.007700935198942724   8.563750320387735e-05  0.002788195694992432     0.8219822379733188  -0.05488896629128472
    7.40000000e+09      0.9998931215965843  0.005862212425338797    -0.1017897839439883  0.007957359597788753   9.16293623237001e-05  0.002865622631170848     0.8217402008552909  -0.05638198791090099
    7.60000000e+09      0.9998916038889967  0.005248006096688408    -0.1017804110360363  0.008212805773480655   9.778565716287209e-05  0.002943062167421599     0.8214920652771128  -0.05787256981162291
    7.80000000e+09      0.9998894844668497  0.004653272581385703    -0.1017711257076571  0.008467351405468379   0.0001041063490011706  0.003020512086866271     0.8212378765249304  -0.05936066627482132
    8.00000000e+09      0.9998868040309954  0.004076535320714725    -0.1017618299386928  0.008721065811490143   0.0001105913862546417  0.003097970319347064     0.8209776801923372  -0.06084623286397193
    8.20000000e+09      0.9998835983359299  0.003516463558252192    -0.1017524392009466  0.008974010988591952   0.0001172407054384919  0.003175434923449699     0.8207115221369667  -0.06232922641144407
    8.40000000e+09      0.9998798988944197  0.002971854722063183    -0.1017428803758917   0.00922624250029707   0.0001240542319537729  0.003252904071143797     0.8204394484381845  -0.06380960500383413
    8.60000000e+09      0.9998757335674879  0.002441619308815258     -0.101733090030207  0.009477810236045228   0.0001310318807328025  0.003330376034608705     0.8201615053559987  -0.06528732796590628
    8.80000000e+09      0.9998711270606393  0.001924767863728749    -0.1017230129816468  0.009728759064052649   0.0001381735567709882  0.003407849174892489     0.8198777392912194   -0.0667623558432044
    9.00000000e+09      0.9998661013430123  0.001420399724134436    -0.1017126011016158  0.009979129394818223   0.000145479155566942  0.003485321932115626      0.819588196747042  -0.06823465038342269
    9.20000000e+09       0.999860676002864  0.0009276932533491822    -0.1017018123115996   0.01022895766937866   0.0001529485634884709  0.003562792816981604     0.8192929242920358  -0.06970417451661025
    9.40000000e+09      0.9998548685502222  0.0004458973390972787    -0.1016906097390438   0.01047827678391693   0.0001605816580784895  0.003640260403397663     0.8189919685246252  -0.07117089233430081
    9.60000000e+09       0.999848694675515  -2.567603098047044e-05    -0.1016789610049237   0.01072711646032064   0.0001683783083121905  0.003717723322042302     0.8186853760391057  -0.07263476906765655
    9.80000000e+09      0.9998421684713528  -0.0004876582729957946    -0.1016668376204964   0.01097550357065796   0.0001763383748146858  0.003795180254742811     0.8183731933932195  -0.07409577106471836
    1.00000000e+10      0.9998353026233591  -0.0009406299204920421    -0.1016542144749192   0.01122346242222147   0.0001844617100465433  0.003872629929548521     0.8180554670773119  -0.07555386576685302
    1.02000000e+10      0.9998281085748906  -0.001385125658118214    -0.1016410693987495   0.01147101500870876   0.000192748158463369  0.003950071116403262      0.817732243485076  -0.07700902168448961
    1.04000000e+10      0.9998205966696586  -0.001821638768065292     -0.101627382791035   0.01171818123222364   0.0002011975566543904  0.004027502623335741     0.8174035688859227  -0.07846120837223941
    1.06000000e+10      0.9998127762755913  -0.002250625067812595    -0.1016131372998576   0.01196497910004932   0.0002098097334640881  0.004104923293098629     0.8170694893989063  -0.07991039640348117
    1.08000000e+10      0.9998046558926946  -0.002672506405974717    -0.1015983175479564    0.0122114248995469   0.0002185845101003408  0.004182332000197842     0.8167300509682975   -0.0813565573445105
    1.10000000e+10      0.9997962432472469  -0.003087673773112698    -0.1015829098964711    0.0124575333540222   0.0002275217002317572  0.004259727648261633     0.8163852993406928  -0.08279966372832867
    1.12000000e+10      0.9997875453742628  -0.003496490076215553    -0.1015669022410171   0.01270331776199266   0.0002366211100765792  0.004337109167706641     0.8160352800437134  -0.08423968902816091
    1.14000000e+10      0.9997785686898795  -0.00389929261856714    -0.1015502838352532   0.01294879012192869   0.0002458825384849181  0.004414475513663989      0.815680038366233  -0.08567660763078047
    1.16000000e+10      0.9997693190550436  -0.004296395320964486    -0.1015330451378895   0.01319396124425647   0.0002553057770160539  0.004491825664133615     0.8153196193401158  -0.08711039480971533
    1.18000000e+10      0.9997598018316768  -0.004688090715227245    -0.1015151776797258   0.01343884085215219   0.0002648906100119213  0.004569158618339347     0.8149540677234535  -0.08854102669841471
    1.20000000e+10      0.9997500219323198  -0.005074651736867386    -0.1014966739478506   0.01368343767245684   0.0002746368146680111  0.004646473395260891     0.8145834279852202  -0.08996848026343823
    1.22000000e+10      0.9997399838641088  -0.005456333340124075    -0.1014775272845735   0.01392775951785376   0.0002845441611023709  0.004723769032322136     0.8142077442913691   -0.0913927332777416
    1.24000000e+10      0.9997296917678098  -0.005833373955639876    -0.1014577317990332   0.01417181336130703   0.0002946124124236324  0.004801044584217625     0.8138270604922679  -0.09281376429411391
    1.26000000e+10      0.9997191494525361  -0.006205996808381521    -0.1014372822897373    0.0144156054036243   0.0003048413247985223  0.004878299121861653     0.8134414201114986  -0.09423155261883352
    1.28000000e+10      0.9997083604266954  -0.006574411111208599     -0.101416174176541   0.01465914113489743   0.000315230647519312  0.004955531731445998     0.8130508663358975  -0.09564607828558604
    1.30000000e+10      0.9996973279256045  -0.006938813147607137    -0.1013944034408006   0.01490242539048408   0.0003257801230717423  0.005032741513594399     0.8126554420068592  -0.09705732202970598
    1.32000000e+10      0.9996860549362165  -0.007299387255423229    -0.1013719665726155   0.01514546240210454   0.000336489487203565   0.00510992758260319     0.8122551896128218  -0.09846526526278247
    1.34000000e+10      0.9996745442192532  -0.007656306721985363    -0.1013488605242218   0.01538825584456259   0.0003473584689940178  0.005187089065758557     0.8118501512828868  -0.09986989004767405
    1.36000000e+10      0.9996627983290844  -0.008009734599855435    -0.1013250826687478   0.01563080887853842   0.0003583867909244825  0.005264225102722424     0.8114403687815447   -0.1012711790739735
    1.38000000e+10      0.9996508196316025  -0.008359824451240727    -0.1013006307636342   0.01587312418984339   0.0003695741689502506   0.00534133484497945     0.8110258835044052   -0.1026691156339517
    1.40000000e+10      0.9996386103203116  -0.008706721028325259    -0.1012755029181332   0.01611520402549022   0.0003809203125738083  0.005418417455338919     0.8106067364749618   -0.1040636835990248
    1.42000000e+10      0.9996261724308457  -0.009050560895804249    -0.1012496975643691   0.01635705022688089   0.0003924249249194208  0.005495472107485582     0.8101829683422559   -0.1054548673967595
    1.44000000e+10      0.9996135078540807  -0.009391473001326256    -0.1012232134315209   0.01659866426039079   0.0004040877028092309  0.005572497985574555     0.8097546193794571   -0.1068426519884513
    1.46000000e+10      0.9996006183479964  -0.009729579198835436     -0.101196049522739   0.01684004724558803   0.000415908336840785  0.005649494283865584     0.8093217294832604   -0.1082270228472939
    1.48000000e+10      0.9995875055484228  -0.01006499472930566    -0.1011682050944677   0.01708119998130725   0.0004278865114660616   0.00572646020639276     0.8088843381740796   -0.1096079659371579
    1.50000000e+10      0.9995741709787899  -0.01039782866286165    -0.1011396796378772   0.01732212296976966   0.0004400219050719165  0.005803394966666026     0.8084424845969764   -0.1109854676919952
    In Untitledd (line 1)
    Error using rf.file.touchstone.Data/createoptionlist
    Invalid option line for the Touchstone format:
    Andrew Beckett over 6 years ago in reply to robert 21
    I can't test this because I don't currently have a MATLAB RF Toolbox license, so can't use the sparameters function. However, the file being produced is a standard Touchstone format, so you should ask The Mathworks about this. Maybe it will accept it if you pick one of the other datatype values (e.g. magphase). Either way, it looks like a bug with the reader in MATLAB. Perhaps it can't cope with the fact that there are different impedances for each port?
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago in reply to robert 21
    The problem is that you have two numbers after the R in the option line, probably because your ports have different impedances. This is not allowed by the specification, see http://www.ibis.org/touchstone_ver2.0/touchstone_ver2_0.pdf
    Andrew Beckett over 6 years ago in reply to Frank Wiedmann
    Frank,
    I think the issue was that only Touchstone 2.0 officially supports multiple reference impedances (that is described in the document  you reference). However, given that Touchstone 1.0 is much more commonly used, this is a fairly common extension to the original format (despite not being covered in the spec; the trouble with ASCII formats is that they are rather easy to extend!). Spectre can also write Touchstone 2.0 (on newer versions of the form it offers the datafmt choice of touchstone2). However, the MATLAB documentation specifically says that the sparameters function doesn't support Touchstone 2.0 so that won't help either, unfortunately!
  • robert 21
    Hello Andrew, Yes when i switched to 50 ohm ports only it worked great.
    So we cant use different impedance ports  touchstone in matlab.
    Thanks.
