  2. RF Design
  3. Sweep harmonic balance (hb) realibility (aging) simulat...
  • Subscribers 63
  • Views 18541
Sweep harmonic balance (hb) realibility (aging) simulation
MAbyk
MAbyk over 6 years ago
hi everyone,
i'm trying to create a netlist for aging simulation. i would like to simulate how power, Gain and PAE (efficiency) are inlfuenced after 3 hours
i would be grateful if someone can correct my syntax in the netlist since i'm trying to make a sweep HB  simulation where the input power is the parameter.
i did it without any error for the sp (S parameters)  simulation.
you can see the images for both sp and hb simulation netlists. (from left to right: sp aging netlist; hb aging netlist)
i will be grateful if someone can provide me some syntax advices.
thanks,
best regards
    Currently sweep analyses are not supported within the reliability analysis (it fails with an error). There's an internal change request (CCR) requesting this: 2154838. You should contact customer support and request that a duplicate is filed on your behalf (it always is best if these come from a customer rather than internal) - please reference the CCR number I mentioned here. Note that because this is to run an RF analysis within aging, it would also require you to have the Legato Reliability Solution product.
  • MAbyk
    MAbyk over 6 years ago in reply to Andrew Beckett
    hi andrew,
    thank you for your answer,
    best regards,
