  2. RF Design
  3. Exporting Sprobe Data to File
  • Subscribers 63
  • Views 18883
mensh
mensh over 6 years ago
Is there a way to export the data from the Sprobe component to a file (e.g. s1p)?
    I don't believe there's anything built-in to do this, but this code could be used after simulation has completed:
    /* abExportSprobeToS1p.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 26, 2020
    Modified
    By
    If you have run an sp analysis and specified some sprobes, you can
    use this function to export to a Touchstone .s1p file. For example:
    abExportSprobeToS1p("I1" "./data.s1p")
    Where I1 is the instance name of the sprobe (note, this needs to be
    a simulator name, so I1.I2 etc rather than using schematic names with /)
    SCCS Info: @(#) abExportSprobeToS1p.il 05/26/20.15:17:29 1.1
    *      (abExportSprobeToS1p instName fileName [?port 'S1]      *
    *                     [?result 'sp_sprobe]                     *
    *                      [?resultsDir nil])                      *
    * Given an instance name (note, using simulator names with dot *
    * separator for hierarchy) and a port name (either S1 or S2),  *
    *     write a Touchstone .s1p representing the sprobe data     *
    (defun abExportSprobeToS1p (instName fileName @key (port 'S1) (result 'sp_sprobe)
                                         resultsDir "SSSSg")
      (let (oport closeAfter sigName data (funcName (getCallingFunction 0))
                  xVec yVec len value)
        ; Bit of basic error checking
        (unless (and
                  (or (stringp port) (symbolp port))
                  (member (upperCase port) '("S1" "S2")))
          (error "%s: port must be S1 or S2 : %L\n" funcName port))
        (setq sigName (strcat instName "." (upperCase port)))
        (setq data (getData sigName ?result result ?resultsDir resultsDir))
        (unless data
          (error "%s: could not access data %s\n" funcName sigName))
        (unless (drIsWaveform data)
          (error "%s: cannot handle family waveform data for %s\n" funcName sigName))
        (setq xVec (drGetWaveformXVec data))
        (setq yVec (drGetWaveformYVec data))
        (setq len (drVectorLength xVec))
        ; Cope with fileName being a port already or a string
        (cond
          ((and (openportp fileName) (outportp fileName))
           (setq oport fileName))
          ((stringp fileName)
           (setq oport (outfile fileName))
           (unless oport
             (error "%s: cannot write to file %s\n" funcName fileName))
           (setq closeAfter t)
          (t
            (error "%s: incorrect filename %L\n" funcName fileName))
        ; Write the header and then the freq, real, imag data
        (fprintf oport "! Touchstone Ver. 1.0\n! Number of ports is 1\n")
        (fprintf oport "# Hz\tS\tRI\tR\t50.000000\n")
        (fprintf oport "! SCATTERING PARAMETERS  :\n")
        (for i 0 (sub1 len)
             (setq value (drGetElem yVec i))
             (fprintf oport "%.14g  %.14g  %.14g\n"
                     (drGetElem xVec i) (real value) (imag value))
        (when closeAfter
          (close oport))
        t
