  2. RF Design
  3. Noise signal as input to RF receiver
  • Subscribers 62
  • Views 16961
engrvip
engrvip over 6 years ago
I want to give a noise signal as input to RF receiver and see its amplification and filtering at various stages of receiver chain.
How can I give noise signal (-174dBm/Hz) as input to circuit ?
If I use a PORT element terminated with 50-Ohm resistor in parallel and use noise temperature as 27 deg. C, then will this arrangement be able to generate above mentioned equivalent noise power output ?
Regards
Vipul
