  2. RF Design
  3. How to use a Lossless Transmission Line in Spectre Transient...
  • Subscribers 63
  • Views 29615
How to use a Lossless Transmission Line in Spectre Transient analysis
RFStuff
RFStuff over 6 years ago
Dear All,
I need to simulate an ideal lossless transmission line with characteristic impedance= Z0 and delay=tau in TRANSIENT simulation.
I went through https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000t1BIEAY&pageName=ArticleContent&sq=0050V000006LcCDQA0_201866111336303.
But here there is no mention of using ideal lossless transmission line with characteristic impedance= Z0 and delay=tau.
Can anybody please tell how to use an ideal lossless transmission line in Spectre Tran Simulation.
Kind Regards,
    Not entirely surprising that an article on transmission line modelling based on their physical properties doesn’t cover ideal transmission lines (the related article referenced below it does mention the tline component, but advises against using it, mainly for modelling lossy lines though).
    if you want a lossless ideal line, use tline from analogLiv and specify the impedance and delay. See “spectre -h tline”, especially the part at the bottom which describes lossless transmission lines.
    Note that one should always be careful with ideal component modelling as these are not what circuit simulators are really best for and can lead to non-physical behaviour (obviously, since a practical transmission line would never be lossless)
  • RFStuff
    RFStuff over 6 years ago in reply to Andrew Beckett
    Thanks a lot Andrew.
    As I see, tline has 13 Instance Parameters however, in the edit property form  is having only 9 parameters. Any specific reason for this ? Can we use Add button to add these remaining parameters ?
    Andrew Beckett over 6 years ago in reply to RFStuff
    I think it's historical. The instance parameters which are not available are also available as model parameters (I have a vague recollection that they were only model parameters in the past).
    So to use them, you either need to create a copy of the tline component, and add the additional parameters into the CDF and the spectre simulation information in the CDF, or define a model and specifiy them that way. However, they are all related to lossy transmission lines, and the article I mentioned before suggests that you don't use the old lossy tline model to represent lossy transmission lines because it's particularly accurate. You can't just add the additional parameters on the create instance or edit properties form because the spectre netlister wouldn't netlist them anyway.
  • Tawna
    Tawna over 6 years ago in reply to RFStuff
    Hi RFStuff,
    The Tool Filter in the Schematic will display the properties supported for a particular simulator (e.g. hspiceD, spectre, ams, etc).
    The spectre -h lists 17 parameters.  Not all are available in the analogLib tline.
    As Andrew mentioned, the tline parameter has been deprecated - the tline model is based on old technology, and not nearly as accurate as the mtline and rfTlineLib elements.  We strongly recommend using the rfTlineLib for transmission line elements.
    best regards,
    Tawna
  • RFStuff
  • RFStuff
    RFStuff over 6 years ago in reply to Tawna
    Thanks Tawna.
