  2. RF Design
  3. Port Noise Error?
  • Subscribers 63
  • Views 20621
Port Noise Error?
hyuksel
hyuksel over 6 years ago
Hey all,
I am using version IC6.18-64b.500.12 with the Spectre version Version 19.1.0.428.isr9 64bit. This is an ADE L simulation.
I am trying the noise figure of a mixer using pnoise. My LO frequency is the main pss harmonic, and the RF input is the small signal.
The port is just a regular 50 Ohm port, with the source type being set to DC. In the pnoise simulation, the input port is the RF port. No matter what box I check (or temperature I put in) in the image below, I keep getting this error:
    WARNING (SPECTRE-16437): Input signal PORT6 contains no noise. NF and F become infinite.
I just want it to present the noise of a 50 Ohm impedance. I have looked through the SpectreRF workshop files for 19.1-18.1-17.1 and I'm following the instructions. Does anybody know what might be causing this error? I even read the port manual and I have no idea what might be going wrong.
Best,
Hazal
    Hi Hazal,
    You shouldn't need to enter a temperature in there - the default is to use 290K (although if you specify the temperature, it's in Celsius) - given that this is the temperature of the port generating the noise, which is deemed to be "off chip" and as part of the virtual lab equipment, it wouldn't normally be at the circuit temperature.
    That said, this wouldn't cause the port to generate no noise. The only things that would do that would be if you set the noise temperature to absolute zero, or set it to not generate noise, or used the noiseon/noiseoff parameters to disable noise from this component.
    Can you please show:
    1. The instance line for the port in your input.scs
    2. All the options and analysis statements from the bottom of the input.scs
  • hyuksel
    hyuksel over 6 years ago in reply to Andrew Beckett
    Hey Andrew,
    I believe this is the information you wanted:
    1. PORT6 (RF_IN GND) port r=50 dc=Vcm type=dc noisetemp=16.85 isnoisy=yes
    I realize that noisetemp here is set to some value, but I get the same error when the field is empty.
    2. simulatorOptions options psfversion="1.4.0" reltol=1e-3 vabstol=1e-6 \
        iabstol=1e-12 temp=25.0 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 \
        rforce=1 vthmod=vthcc ivthn=300e-9 ivthp=70e-9 ivthw=0 ivthl=0 \
        sensfile="../psf/sens.output" checklimitdest=psf vdsatmod=gds
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    pss  pss  fund=1G  harms=10  errpreset=moderate  annotate=status
    pnoise  pnoise  sweeptype=relative  relharmnum=1  start=1k
    +       stop=5M  dec=5  maxsideband=10  oprobe=PORT2  iprobe=PORT6
    +       refsideband=1  noiseout=[usb]  annotate=status
    The input port is PORT6. The overall simulation temperature set in the ADE L window is 25C.
    Thanks again,
    Hazal
    Andrew Beckett over 6 years ago in reply to hyuksel
    I ran with a simple cut-down netlist adding this to your options and analysis statements:
    parameters Vcm=1.0
    R1 (RF_IN RF_OUT) resistor r=1k
    PORT2 (RF_OUT GND) port r=50
    It runs with no problems. Can you please post the entire spectre.out log file (probably as an attachment to the post)? It might give a clue as to why it thinks this port is noiseless - it seems very strange to me.
  • hyuksel
    For some reason it will not allow an attachment - when I try to upload just gives a 0% progress bar and quits. Sorry for the wall of text - here is the entire log file:
    Spectre (R) Circuit Simulator
    Version 19.1.0.428.isr9 64bit -- 25 Jul 2020
    Copyright (C) 1989-2020 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    System load averages (1min, 5min, 15min) : 0.6 %, 0.6 %, 0.9 %
    Hyperthreading is enabled
    Simulating `input.scs' on defiant at 9:03:13 AM, Wed Aug 19, 2020 (process id: 83331).
    Current working directory:
    Command line:
        /home/data/tools/cadence/current_MMSIM/tools/bin/spectre -64  \
            input.scs +escchars +log ../psf/spectre.out -format psfxl -raw  \
            ../psf +lqtimeout 900 -maxw 5 -maxn 5 -env ade +lqt 0
    Loading /home/data/tools/cadence/current_MMSIM/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Loading /home/data/tools/cadence/current_MMSIM/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
    Loading /home/data/tools/cadence/current_MMSIM/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
    Loading /home/data/tools/cadence/current_MMSIM/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
    Loading /home/data/tools/cadence/current_MMSIM/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
    Reading file:
    Reading link:  /home/data/tools/cadence/current_MMSIM
    Reading file:  /home/data/tools/cadence/SPECTRE191/tools.lnx86/spectre/etc/configs/spectre.cfg
    Reading link:  /home/data/pdks/gf/22FDX-EXT/current_rev
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/design_wrapper_rf.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/design.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/shared.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/shared.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/beol.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/beol.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/wire_fixed_corner.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/metalwire.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/skew.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/montecarlo.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/correlation.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fixed_corner.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fet_od_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fet_mc_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fet_mm_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fet_misc_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/lle_equation.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/lle_param.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_bfmoatnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_dphnfetpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_dphnfetwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_dphpfetpu.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eglvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eglvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egslvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egslvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egullpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egulvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egulvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eguslvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eguslvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvlvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvlvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvslvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvslvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egzvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_elvtxpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_hvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_hvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_llhvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_llhvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_lvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_lvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_nfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_pfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_slvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_slvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spgnfetpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spgnfetwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spgpfetpu.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spinfetpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spinfetwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spipfetpu.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spjnfetpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spjnfetwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spjpfetpu.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spvnfetpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spvnfetwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_spvpfetpu.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_tpbnfetpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_tpbnfetrpd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_tpbnfetrwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_tpbnfetwl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_tpbpfetpu.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_uhvtnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_uhvtpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_auxpc2.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_auxpc5.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_float.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_weakbit.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_cnrx.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_rf.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eglvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eglvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egslvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egslvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egulvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egulvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eguslvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_eguslvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvlvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvlvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvslvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_egvslvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_elvtxpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_hvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_hvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_lvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_lvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_nfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_pfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_slvtnfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_slvtpfet_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_rf_4t.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_rf_5t.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_rf_6t.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_rf_geo_eqn.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/fets_rf_sub.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/variation.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/ldfets.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet3p3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet5p0.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet6p5.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet3p3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet5p0.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet6p5.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet3p3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet5p0.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet6p5.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/ldfets_rf.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet3p3_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet3p3_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet5p0_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet5p0_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet6p5_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_btbldnfet6p5_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet3p3_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet3p3_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet5p0_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet5p0_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet6p5_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldnfet6p5_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet3p3_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet3p3_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet5p0_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet5p0_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet6p5_addon_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_ldpfet6p5_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/boxfets.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_bxnfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/model_bxpfet.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdfets.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diode_param.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/passive_fixed_corner.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diode_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/schky_mmw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/schky.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/tdndsx.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/tdpdnw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/tdndsx_nolvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/tdpdnw_nolvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egtdndsx_nolvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egtdpdnw_nolvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodenx.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodepnw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodenwx.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodetwx.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodepwtw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodenwx_lvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodetwx_lvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/diodepwtw_lvs.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egdiodenx.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egdiodepnw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egtdndsx.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egtdpdnw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/efuse.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/passive_fixed_corner_rf.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/tline_rf.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/cpw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/msl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/cpwg.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/coupledcpw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/coupledmsl.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/coupledcpwg.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/inductor.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/inductor_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option1.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option4.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option5.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option6.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option15.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option16.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option7.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option8.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symindp_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/sym_core.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option1.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option4.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option5.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option6.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option15.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option16.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option7.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option8.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_core.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/symct_core_ctw.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option1.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option4.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option5.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option6.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option15.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option16.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option7.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option8.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/indp_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/xformer.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/xformer_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_xformer.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_xformer_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_xformer_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_xformer_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_xformer_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_xformer.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_xformer_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_xformer_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_xformer_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_xformer_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/balun.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/balun_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_balun.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_balun_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_balun_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_balun_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/int_balun_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_balun.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_balun_option11.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_balun_option13.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_balun_option17.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/stk_balun_option20.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/paracap.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom1v8_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom3v3_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom4v_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom5v_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mom7v_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mom10v_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom1v8.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom3v3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom4v.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/apmom5v.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mom7v.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mom10v.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mosvar_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mosvar_param.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mosvar.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mosvar_eqn.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mosvar_dio.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/mosvar_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/resistor_param.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/resistor_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/opnpcres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/opndres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/opndressoi.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/oppdres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/nwres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/reopnpcres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/reopnarnpcres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/npcres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/lvsres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/opnpcres_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/reopnpcres_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/reopnarnpcres_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/npcres_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/opndressoi_rf.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/bipolar.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/vpnp.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/vnpn.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esd_modules.va
    Warning from spectre during AHDL read-in.
        WARNING (VACOMP-2435): The environment variable CDS_AHDLCMI_ENABLE is no longer supported. Therefore, the simulator will use the default compiled C code flow.
    Reading file:  /home/data/tools/cadence/SPECTRE191/tools.lnx86/spectre/etc/ahdl/constants.vams
    Reading file:  /home/data/tools/cadence/SPECTRE191/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esd_param.lib.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esd_param.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdndsx_sti.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdpdnw_sti.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdegndsx_poly.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdegpdnw_poly.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdegvnpn_poly.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdvnpn_sti.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdlpnp.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdndres.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdnsh.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdnsh_stk.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdscr.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdscr_t3.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdnsh_va.va
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdnsh_stk_va.va
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/egnfet_esd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/nfet_esd.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdpsh.scs
    Reading file:  /home/data/pdks/gf/22FDX-EXT/V0.9_1.0_A1/Models/Spectre/models/esdpsh_va.va
    Time for NDB Parsing: CPU = 1.55004 s, elapsed = 2.02299 s.
    Time accumulated: CPU = 1.66234 s, elapsed = 2.02301 s.
    Peak resident memory used = 123 Mbytes.
    Existing shared object for module esdnsh_va is up to date.
    Installed compiled interface for esdnsh_va.
    Existing shared object for module esdpsh_va is up to date.
    Installed compiled interface for esdpsh_va.
    Reading link:  /home/data/tools/cadence/current_MMSIM/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading link:  /home/data/tools/cadence/current_MMSIM/tools.lnx86/spectre/etc/ahdl/constants.h
    Existing shared object for module bsource_7c8f41 is up to date.
    Installed compiled interface for bsource_7c8f41.
    Existing shared object for module bsource_resnoise_r_d794c7 is up to date.
    Installed compiled interface for bsource_resnoise_r_d794c7.
    Existing shared object for module bsource_resnoise_r_d794c7a is up to date.
    Installed compiled interface for bsource_resnoise_r_d794c7a.
    Time for Elaboration: CPU = 578.856 ms, elapsed = 597.702 ms.
    Time accumulated: CPU = 2.24142 s, elapsed = 2.62093 s.
    Peak resident memory used = 182 Mbytes.
    Warning from spectre during hierarchy flattening.
        WARNING (SPECTRE-17101): The value 'psf' specified for the 'checklimitdest' option will no longer be supported in future releases. Use 'spectre -h' to see other recommended values for the 'checklimitdest' option.
    Notice from spectre in `eglvtpfet':`I44.I18.I10.I11.P3', in `HY_RX_BB_AMP_BIAS':`I44.I18.I10.I11', in `HY_RX_BB_AMP_DIFF':`I44.I18.I10', in `HY_RX_BB_AMP_DIFF_wRES_v2':`I44.I18', in `HY_BB_Top':`I44', during hierarchy flattening.
        I44.I18.I10.I11.P3.csb: Terminals are connected together (to node `VDD_BB').
    Notice from spectre in `eglvtpfet':`I44.I18.I10.I11.P1', in `HY_RX_BB_AMP_BIAS':`I44.I18.I10.I11', in `HY_RX_BB_AMP_DIFF':`I44.I18.I10', in `HY_RX_BB_AMP_DIFF_wRES_v2':`I44.I18', in `HY_BB_Top':`I44', during hierarchy flattening.
        I44.I18.I10.I11.P1.csb: Terminals are connected together (to node `VDD_BB').
    Notice from spectre in `eglvtpfet':`I44.I18.I10.I11.P2', in `HY_RX_BB_AMP_BIAS':`I44.I18.I10.I11', in `HY_RX_BB_AMP_DIFF':`I44.I18.I10', in `HY_RX_BB_AMP_DIFF_wRES_v2':`I44.I18', in `HY_BB_Top':`I44', during hierarchy flattening.
        I44.I18.I10.I11.P2.csb: Terminals are connected together (to node `VDD_BB').
    Notice from spectre in `eglvtpfet':`I44.I18.I10.I11.P6', in `HY_RX_BB_AMP_BIAS':`I44.I18.I10.I11', in `HY_RX_BB_AMP_DIFF':`I44.I18.I10', in `HY_RX_BB_AMP_DIFF_wRES_v2':`I44.I18', in `HY_BB_Top':`I44', during hierarchy flattening.
        I44.I18.I10.I11.P6.csb: Terminals are connected together (to node `VDD_BB').
    Notice from spectre in `eglvtpfet':`I44.I18.I10.I11.P0', in `HY_RX_BB_AMP_BIAS':`I44.I18.I10.I11', in `HY_RX_BB_AMP_DIFF':`I44.I18.I10', in `HY_RX_BB_AMP_DIFF_wRES_v2':`I44.I18', in `HY_BB_Top':`I44', during hierarchy flattening.
        I44.I18.I10.I11.P0.csb: Terminals are connected together (to node `VDD_BB').
            Further occurrences of this notice will be suppressed.
    Time for EDB Visiting: CPU = 99.234 ms, elapsed = 98.875 ms.
    Time accumulated: CPU = 2.34079 s, elapsed = 2.71994 s.
    Peak resident memory used = 195 Mbytes.
    Notice from spectre during topology check.
        Only one connection to the following 2 nodes:
            net026
            net027
        No DC path from node `I44.VDD' to ground, Gmin installed to provide path.
        No DC path from node `I43.VDD' to ground, Gmin installed to provide path.
    Global user options:
          ignorezerovar = yes
             psfversion = 1.4.0
                vabstol = 1e-06
                iabstol = 1e-12
                   temp = 25
                   gmin = 1e-12
                 rforce = 1
                 vthmod = vthcc
                  ivthn = 3e-07
                  ivthp = 7e-08
                  ivthw = 0
                  ivthl = 0
               maxnotes = 5
               maxwarns = 5
                 digits = 5
                   cols = 80
                 pivrel = 0.001
               sensfile = ../psf/sens.output
         checklimitdest = psf
               vdsatmod = gds
                   save = allpub
                 reltol = 0.001
                   tnom = 27
                 scalem = 1
                  scale = 1
    Scoped user options:
    Circuit inventory:
                  nodes 6172
                bsimimg 298
         bsource_7c8f41 56
    bsource_resnoise_r_d794c7 540
    bsource_resnoise_r_d794c7a 6
              capacitor 3214
               inductor 672
                isource 2
              juncap200 296
                   port 4
               resistor 3313
            transformer 4
                   vcvs 2
                vsource 54
    Analysis and control statement inventory:
                     dc 1
                   info 7
                 pnoise 1
                    pss 1
    Output statements:
                 .probe 0
               .measure 0
                   save 0
    Notice from spectre.
        53 notices suppressed.
    Time for parsing: CPU = 126.924 ms, elapsed = 128.528 ms.
    Time accumulated: CPU = 2.46782 s, elapsed = 2.84857 s.
    Peak resident memory used = 200 Mbytes.
    Pre-Simulation Summary
    DC Analysis `dcOp'
    Finding DC approximate solution failed with try_fast_op=yes, continue running with try_fast_op=no.
    Opening the PSF file ../psf/dcOp.dc ...
    Important parameter values:
        reltol = 1e-03
        abstol(V) = 1 uV
        abstol(I) = 1 pA
        temp = 25 C
        tnom = 27 C
        tempeffects = all
        gmindc = 1 pS
    Trying `homotopy = gmin'.
    Continuation method failed. Step size is too small.
    Trying `homotopy = source'.
    Notice from spectre during DC analysis `dcOp'.
        Bad pivoting is found during DC analysis. Option dc_pivot_check=yes is recommended for possible improvement of convergence.
    Maximum value achieved for any signal of each quantity:
    V: V(CL_CTRL<0>) = 1.8 V
    I: I(V7:p) = 80.4 mA
    Convergence achieved in 573 iterations.
    DC simulation time: CPU = 1.20729 s, elapsed = 1.21017 s.
    Total time required for dc analysis `dcOp': CPU = 1.20746 s, elapsed = 1.21033 s.
    Time accumulated: CPU = 3.68356 s, elapsed = 4.07095 s.
    Peak resident memory used = 208 Mbytes.
    dcOpInfo: writing operating point information to rawfile.
    Opening the PSF file ../psf/dcOpInfo.info ...
    Warning from spectre during info `dcOpInfo'.
        WARNING (CMI-2454): I43.I18.I11.I16.P0: Calculation of the constant current Vth failed, and model equation Vth is used in the output. Please check the parameters ivth/ivthn/ivthp and ivth_vdsmin.
        WARNING (CMI-2454): I43.I18.I11.I17.P0: Calculation of the constant current Vth failed, and model equation Vth is used in the output. Please check the parameters ivth/ivthn/ivthp and ivth_vdsmin.
        WARNING (CMI-2454): I43.I18.I11.I4.P0: Calculation of the constant current Vth failed, and model equation Vth is used in the output. Please check the parameters ivth/ivthn/ivthp and ivth_vdsmin.
        WARNING (CMI-2454): I43.I18.I11.I9.P0: Calculation of the constant current Vth failed, and model equation Vth is used in the output. Please check the parameters ivth/ivthn/ivthp and ivth_vdsmin.
        WARNING (CMI-2454): I44.I18.I11.I16.P0: Calculation of the constant current Vth failed, and model equation Vth is used in the output. Please check the parameters ivth/ivthn/ivthp and ivth_vdsmin.
            Further occurrences of this warning will be suppressed.
        55 warnings suppressed.
    Periodic Steady-State Analysis `pss': fund = 1 GHz
    DC simulation time: CPU = 27.809 ms, elapsed = 27.7081 ms.
    `pss': time = (0 s -> 1 ns)
    Output and IC/nodeset summary:
                     save   730     (current)
                     save   4274    (voltage)
    Important parameter values in tstab integration:
        start = 0 s
        outputstart = 0 s
        stop = 1 ns
        period = 1 ns
        maxperiods = 20
        step = 1 ps
        maxstep = 40 ps
        ic = all
        useprevic = no
        skipdc = no
        reltol = 1e-03
        abstol(V) = 1 uV
        abstol(I) = 1 pA
        temp = 25 C
        tnom = 27 C
        tempeffects = all
        method = traponly
        lteratio = 3.5
        relref = sigglobal
        cmin = 0 F
        gmin = 1 pS
        pss: time = 25.83 ps    (2.58 %), step = 1.226 ps     (123 m%)
        pss: time = 81.18 ps    (8.12 %), step = 6.251 ps     (625 m%)
        pss: time = 131.2 ps    (13.1 %), step = 9.376 ps     (938 m%)
        pss: time = 181.8 ps    (18.2 %), step = 15.52 ps     (1.55 %)
        pss: time = 225.2 ps    (22.5 %), step = 12.97 ps      (1.3 %)
        pss: time = 275.4 ps    (27.5 %), step = 790.3 fs      (79 m%)
        pss: time = 333.4 ps    (33.3 %), step = 9.631 ps     (963 m%)
        pss: time = 383.4 ps    (38.3 %), step = 10.31 ps     (1.03 %)
        pss: time = 427 ps      (42.7 %), step = 2.244 ps     (224 m%)
        pss: time = 477.3 ps    (47.7 %), step = 7.432 ps     (743 m%)
        pss: time = 525.2 ps    (52.5 %), step = 697.8 fs    (69.8 m%)
        pss: time = 578.1 ps    (57.8 %), step = 5.478 ps     (548 m%)
        pss: time = 639.2 ps    (63.9 %), step = 15.72 ps     (1.57 %)
        pss: time = 689.8 ps      (69 %), step = 17.42 ps     (1.74 %)
        pss: time = 730.4 ps      (73 %), step = 8.006 ps     (801 m%)
        pss: time = 775.3 ps    (77.5 %), step = 611.5 fs    (61.2 m%)
        pss: time = 827.1 ps    (82.7 %), step = 6.017 ps     (602 m%)
        pss: time = 889.8 ps      (89 %), step = 15.81 ps     (1.58 %)
        pss: time = 940.5 ps      (94 %), step = 17.45 ps     (1.75 %)
        pss: time = 981.3 ps    (98.1 %), step = 8.378 ps     (838 m%)
    Total time required for tstab analysis `pss': CPU = 1.26931 s, elapsed = 1.2654 s.
    Time accumulated: CPU = 5.0862 s, elapsed = 5.50641 s.
    Peak resident memory used = 211 Mbytes.
    Conv norm = 64.7e+03, max dV(I30.I3.N3:int_di) = 900.116 mV, took 1.28 s.
    Important parameter values in pss iteration:
        start = 0 s
        outputstart = 0 s
        stop = 1 ns
        period = 1 ns
        maxperiods = 20
        steadyratio = 1e-03
        step = 1 ps
        maxstep = 5 ps
        ic = all
        useprevic = no
        skipdc = no
        reltol = 1e-03
        abstol(V) = 1 uV
        abstol(I) = 1 pA
        temp = 25 C
        tnom = 27 C
        tempeffects = all
        errpreset = moderate
        method = gear2only
        lteratio = 3.5
        relref = alllocal
        cmin = 0 F
        gmin = 1 pS
        pss: time = 25.35 ps    (2.54 %), step = 396.3 fs    (39.6 m%)
        pss: time = 79.13 ps    (7.91 %), step = 4.277 ps     (428 m%)
        pss: time = 129.1 ps    (12.9 %), step = 5 ps         (500 m%)
        pss: time = 179.1 ps    (17.9 %), step = 5 ps         (500 m%)
        pss: time = 228 ps      (22.8 %), step = 3.908 ps     (391 m%)
        pss: time = 275.1 ps    (27.5 %), step = 366.7 fs    (36.7 m%)
        pss: time = 329.3 ps    (32.9 %), step = 4.834 ps     (483 m%)
        pss: time = 379.3 ps    (37.9 %), step = 5 ps         (500 m%)
        pss: time = 429.3 ps    (42.9 %), step = 5 ps         (500 m%)
        pss: time = 478.4 ps    (47.8 %), step = 4.086 ps     (409 m%)
        pss: time = 525.4 ps    (52.5 %), step = 425.5 fs    (42.6 m%)
        pss: time = 578.9 ps    (57.9 %), step = 4.315 ps     (432 m%)
        pss: time = 628.9 ps    (62.9 %), step = 5 ps         (500 m%)
        pss: time = 678.9 ps    (67.9 %), step = 5 ps         (500 m%)
        pss: time = 727.9 ps    (72.8 %), step = 3.982 ps     (398 m%)
        pss: time = 775 ps      (77.5 %), step = 360.8 fs    (36.1 m%)
        pss: time = 829.2 ps    (82.9 %), step = 4.732 ps     (473 m%)
        pss: time = 879.2 ps    (87.9 %), step = 5 ps         (500 m%)
        pss: time = 929.2 ps    (92.9 %), step = 5 ps         (500 m%)
        pss: time = 978.3 ps    (97.8 %), step = 4.066 ps     (407 m%)
    Conv norm = 8.22e+03, max dV(I30.I1.N7.nfet_rf_6t.gpre) = 152.545 mV, took 2.96 s.
        pss: time = 25.01 ps     (2.5 %), step = 399 fs      (39.9 m%)
        pss: time = 79.61 ps    (7.96 %), step = 4.667 ps     (467 m%)
        pss: time = 129.6 ps      (13 %), step = 5 ps         (500 m%)
        pss: time = 179.6 ps      (18 %), step = 5 ps         (500 m%)
        pss: time = 228.5 ps    (22.9 %), step = 3.949 ps     (395 m%)
        pss: time = 275.3 ps    (27.5 %), step = 402.1 fs    (40.2 m%)
        pss: time = 329.5 ps      (33 %), step = 4.656 ps     (466 m%)
        pss: time = 379.5 ps      (38 %), step = 5 ps         (500 m%)
        pss: time = 429.5 ps      (43 %), step = 5 ps         (500 m%)
        pss: time = 478.5 ps    (47.8 %), step = 3.964 ps     (396 m%)
        pss: time = 525.3 ps    (52.5 %), step = 402.1 fs    (40.2 m%)
        pss: time = 579.5 ps      (58 %), step = 4.649 ps     (465 m%)
        pss: time = 629.5 ps      (63 %), step = 5 ps         (500 m%)
        pss: time = 679.5 ps      (68 %), step = 5 ps         (500 m%)
        pss: time = 728.5 ps    (72.8 %), step = 3.967 ps     (397 m%)
        pss: time = 775.3 ps    (77.5 %), step = 402.1 fs    (40.2 m%)
        pss: time = 829.5 ps      (83 %), step = 4.656 ps     (466 m%)
        pss: time = 879.5 ps      (88 %), step = 5 ps         (500 m%)
        pss: time = 929.5 ps      (93 %), step = 5 ps         (500 m%)
        pss: time = 978.5 ps    (97.8 %), step = 3.963 ps     (396 m%)
    Conv norm = 5.31e+03, max dV(I44.I18.I10.I0.P3:int_di) = -92.9833 mV, took 2.84 s.
    Conv norm = 1.27e+03, max dI(V30:p) = -946.887 uA, took 2.54 s.
    Conv norm = 608, max dI(V30:p) = -466.958 uA, took 2.55 s.
    Conv norm = 62.9, max dV(I43.I18.I10.I0.P3:int_di) = 1.01874 mV, took 2.55 s.
    Conv norm = 72.4, max dV(I43.I18.I10.I0.P3:int_di) = 1.16452 mV, took 2.55 s.
    Conv norm = 43.8, max dV(I44.I18.I10.I0.P3:int_di) = 703.224 uV, took 2.55 s.
    Conv norm = 16.7, max dV(I44.I18.I10.I0.P3:int_di) = 268.53 uV, took 2.55 s.
    Conv norm = 4.83, max dV(I44.I18.I10.I10.P3:int_di) = 77.5518 uV, took 2.55 s.
    Conv norm = 750e-03, max dV(I44.I18.I10.I10.C1.xCore.5) = -15.0328 uV, took 2.55 s.
    Opening the PSF file ../psf/pss.td.pss ...
    Opening the PSF file ../psf/pss.fd.pss ...
    V: V(I44.I18.I10.I11.P3:int_di) = 1.869 V
    I: I(V7:p) = 128 mA
    Initial condition solution time: CPU = 27.93 ms, elapsed = 27.8311 ms.
    pss: The steady-state solution was achieved in 11 iterations.
    Number of accepted pss steps =             516
    Total time required for pss analysis `pss': CPU = 37.8344 s, elapsed = 37.9935 s.
    Time accumulated: CPU = 41.5758 s, elapsed = 42.1561 s.
    Peak resident memory used = 508 Mbytes.
    Periodic Noise Analysis `pnoise': freq = 1 GHz + (1 kHz -> 5 MHz)
    Opening the PSF file ../psf/pnoise.pnoise ...
    Input frequency range = 2 GHz + (1 kHz -> 5 MHz).
    Using the operating-point information generated by PSS analysis `pss'.
    Warning from spectre at freq = 1 kHz during PNoise analysis `pnoise'.
    Warning from spectre at freq = 1.58489 kHz during PNoise analysis `pnoise'.
        pnoise: freq = 1.585 kHz   (5.56 %), step = 584.9 Hz     (5.56 %)
        pnoise: freq = 2.512 kHz   (11.1 %), step = 927 Hz       (5.56 %)
        pnoise: freq = 3.981 kHz   (16.7 %), step = 1.469 kHz    (5.56 %)
        pnoise: freq = 6.31 kHz    (22.2 %), step = 2.329 kHz    (5.56 %)
        pnoise: freq = 10 kHz      (27.8 %), step = 3.69 kHz     (5.56 %)
        pnoise: freq = 15.85 kHz   (33.3 %), step = 5.849 kHz    (5.56 %)
        pnoise: freq = 25.12 kHz   (38.9 %), step = 9.27 kHz     (5.56 %)
        pnoise: freq = 39.81 kHz   (44.4 %), step = 14.69 kHz    (5.56 %)
        pnoise: freq = 63.1 kHz      (50 %), step = 23.29 kHz    (5.56 %)
        pnoise: freq = 100 kHz     (55.6 %), step = 36.9 kHz     (5.56 %)
        pnoise: freq = 158.5 kHz   (61.1 %), step = 58.49 kHz    (5.56 %)
        pnoise: freq = 251.2 kHz   (66.7 %), step = 92.7 kHz     (5.56 %)
        pnoise: freq = 398.1 kHz   (72.2 %), step = 146.9 kHz    (5.56 %)
        pnoise: freq = 631 kHz     (77.8 %), step = 232.9 kHz    (5.56 %)
        pnoise: freq = 1 MHz       (83.3 %), step = 369 kHz      (5.56 %)
        pnoise: freq = 1.585 MHz   (88.9 %), step = 584.9 kHz    (5.56 %)
        pnoise: freq = 2.512 MHz   (94.4 %), step = 927 kHz      (5.56 %)
        pnoise: freq = 5 MHz        (100 %), step = 2.488 MHz    (5.56 %)
    Total time required for pnoise analysis `pnoise': CPU = 23.2502 s, elapsed = 23.1681 s.
    Time accumulated: CPU = 64.8424 s (1m  4.8s), elapsed = 65.3459 s (1m  5.3s).
    Peak resident memory used = 560 Mbytes.
        52 warnings suppressed.
    modelParameter: writing model parameter values to rawfile.
    Opening the PSF file ../psf/modelParameter.info ...
    element: writing instance parameter values to rawfile.
    Opening the PSF file ../psf/element.info ...
    outputParameter: writing output parameter values to rawfile.
    Opening the PSF file ../psf/outputParameter.info ...
    designParamVals: writing netlist parameters to rawfile.
    Opening the PSFASCII file ../psf/designParamVals.info ...
    primitives: writing primitives to rawfile.
    Opening the PSFASCII file ../psf/primitives.info.primitives ...
    subckts: writing subcircuits to rawfile.
    Opening the PSFASCII file ../psf/subckts.info.subckts ...
    Aggregate audit (9:04:18 AM, Wed Aug 19, 2020):
    Time used: CPU = 65.2 s (1m  5.2s), elapsed = 65.8 s (1m  5.8s), util. = 99.1%.
    Time spent in licensing: elapsed = 133 ms.
    Peak memory used = 560 Mbytes.
    Simulation started at: 9:03:13 AM, Wed Aug 19, 2020, ended at: 9:04:18 AM, Wed Aug 19, 2020, with elapsed time (wall clock): 65.8 s (1m  5.8s).
    spectre completes with 0 errors, 12 warnings, and 13 notices.
    Please contact customer support - this seems to be something peculiar to the test case you have here as I cannot reproduce it, and cannot see anything in the log file which gives any clues. Even if I explicitly disable the noise from the port (e.g. using the noiseoff_inst option), all that happens then is that it doesn't compute F or NF but doesn't complain about it. So something else is going on. Also, using noiseoff_inst/noiseon_inst shows up in the log file, so it must be something else...
    I found some very old issues related to this (long fixed) and these were bugs (it was only a couple of reports from many years ago though).
