  2. RF Design
  3. Warnings from spectre PSS analysis
  • Subscribers 63
  • Views 16400
MohanB
MohanB over 6 years ago
While running a harmonic balance analysis on my rectifier, I receive warnings such as '
CMI-2426: M3: Cdscd = -28 is negative.
CMI-2426: M1: Pdiblc2 = -31 is negative.
I understand that these are parameters of the MOSFETs specified in  the specific PDK, but I have no idea why they keep popping up?
Any clues for the same would be great!
    It's quite likely that there's a problem with the models of the PDK you're using. You might want to speak with customer support about this - or with the foundry. Check you're running with the latest available models and latest SPECTRE and see whether it goes away, but I would be cautious because it suggests that a model region is wrong (it might be that some of the capacitances are missing in the models).
