  2. RF Design
  3. Eye Aperture isn't taking place at values of my interes...
  • Subscribers 63
  • Views 4400
Eye Aperture isn't taking place at values of my interest
ventati1990
ventati1990 over 6 years ago
Hi , In the image attached, its a combination of 8 eye diagrams. I am using eye aperture calc function for automatic generation of the mask.  My desired vref is 660mv, VHiDC = 785mv (verf+125mv) & VHiAC = 810mv(Vref+150mv). Eye aperture fails to evaluate at these values because eye opening maximum is 741mv where V1 & H1 intersects, where  V2 &H1 intersects it can evaluate. But it evaluate only at V1 crossing not V2. Is there any way to evaluate and create mask connecting  between 810 mv & 785mv ?
If i try have custom mask of my own, tool let me select only one mask at a time. Is there any way to apply custom mask to all 8 eye diagrams in one go?
    I would suggest you contact customer support for this. Others may be able to help, but I don't have enough spare time today (I answer here in spare minutes throughout the day) to set up an example and test this out to fully check what you're saying...
  • ventati1990
    ventati1990 over 6 years ago in reply to Andrew Beckett
    Hi Andrew, Thank you for your time. I have access to tool only but not to customer support. As it seems no one replied, if you can provide the solution after few days is also ok to me.
