  2. RF Design
  3. [AWR Microwave Office] Harmonic Balance in Load-Pull an...
  • Subscribers 64
  • Views 17924
[AWR Microwave Office] Harmonic Balance in Load-Pull analysis
Eres
Eres over 6 years ago
Hello everyone,
I've short question related to AWR Microwave Office. I need to turn on Harmonic Balance in Load-Pull analysis. I've library with elements which can be calculated only in HB, so when I try to calculate load-pull in AWR I see error related to translator ("Cannot find the translator for this element").  So how can I turn-on such option manually ? It is possible ?
E.
  • GraemeR
    GraemeR over 6 years ago +1
    Hi Eres, You are likely seeing this error because the model you are trying to use doesn't run in the APLAC HB solver. If you right click on the background of the load-pull template schematic you can…
  • GraemeR
    Hi Eres,
    You are likely seeing this error because the model you are trying to use doesn't run in the APLAC HB solver.   If you right click on the background of the load-pull template schematic you can switch to using the legacy HB solver in the user attributes section.
    Best Regards,
    Graeme
  • Eres
    Eres over 6 years ago in reply to GraemeR
    Hi GraemeR,
    that's exactly what it meant! Thank you for your help !
    Best Regards,
    E.
