  2. RF Design
  3. Calculations with signal bus outputs in Cadence calcula...
  • Subscribers 63
  • Views 15286
Calculations with signal bus outputs in Cadence calculator
DKaraca
DKaraca over 5 years ago
My question is as follows:
I run an ac test and save two signal buses in bundle form: /inp<1:32> & /inm<1:32>
Then I calculate the ac response of each:
Vinp=VF("/inp<1:32>")
Vinm=VF("/inm<1:32>")
Until this point, all is fine. I can plot Vinp & Vinm successfully (each having 32 traces).
However, the calculator fails to compute Vinp-Vinm (or any similar calculation).
Intuitively, I expect to get a new waveform family where each trace gives VF("/inp<N>")-VF("/inp<N>") for N=1:1:32
I suppose the problem is that "bit" variable in the two waveform families is not identical.
Could you please advise me about how to solve this?
My Cadence version is: IC6.1.7-64b.500.23
Thanks in advance.
BR,
Denizhan Karaca
    Hi Denizhan,
    I tried this in the latest IC6.1.8 ISR (ISR14) and it fails there too - I can subtract a non-bussed net from a bus, but not one bus from another. This ought to be possible (in principle), so please contact customer support. It needs a fix from R&D, I believe.
