  2. RF Design
  3. Why don't PAE vs PT (Total Power) measurements agree?
  • Subscribers 62
  • Views 4111
FormerMember
FormerMember over 5 years ago
I'm tuning an NXP LDMOS FET model in Microwave Office.  When my Vds current is about 20A at 12V, my output power on port 2 measured by the "PT" Total Power measurement shows ~100W (which is our optimization target).
Here is the part I don't understand:  Why does PAE show about 75%?    Shouldn't 100W/240W have a PAE of ~41%?
Port 1 (Pin) is 17dBm, so 0.050 Watts, a negligible amount.
(Pout-Pin)/Pdc == (100-0.050)/240W == 0.416.
What am I missing here?
Thanks for your help!
-Eric
  • FormerMember
    Here is some more info if someone is available to help:
    This  isa screenshot of the schematic and I've attached the .emp file.
    There are two fets, a pre-amp using about 15mA and a power amp using 19.39 A.
    Graph2 shows the current across the ideal DCVS's for the two drain-source's.
    Graph3 shows the total power (PT) of port2 and PAE of port1,2.
    Any idea why MWO is showing 75-82% PAE when my hand-calculation shows much less?
    The NXP models are available on the NXP site for these fets:
    • https://www.nxp.com/docs/en/data-sheet/AFT05MP075N.pdf
      • AWR Model:
      • www.nxp.com/.../license.jsp
    • https://www.nxp.com/docs/en/data-sheet/AFT05MS004N.pdf
      • AWR Model:
      • https://www.nxp.com/webapp/sps/download/license.jsp?colCode=AFT05MS004N_MDL_AWR&location=null
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/33/75watt_2D00_amp.zip
  • FormerMember
    FormerMember over 5 years ago in reply to FormerMember
    Also note that ports 3,4,5,6 are just to confirm that the LC bias tee is minimizing RF leakage into the power supply.  DB[S3,1] through S6,1 are all <-60db.  They aren't involved in the amplification except to measure RF leakage.
  • FormerMember
    I made a PAE_Error output equation so when PAE_Error==1 there is no error.  >1 means AWR's PAE is too high, <1 means too low.  Interestingly, when I disabled the pre-amp fet (the first FET in the schematic) I am able to optimize and get PAE_Error=1.008, so its probably correct.  I wonder why it would be thrown off by the 2nd fet?
    Another anomaly is that the input port is 16.4dBm, the FET provides a 19.2 dB gain, which should be 3.6W of output---but PT_port2 shows 85W of output!  Why 85W?  I mean, I want that much output ultimately, but the S21 gain does not agree with the PT_port2 measurement that AWR is providing.
    Is this a problem in the way I am measuring in AWR or a problem with NXP's FET model?
  • FormerMember
    Well, I've stripped it down to a single FET: Vds is 12V, Ids is 7.6A (91.2 W). PORT1/Pwr input to the FET is 36dBm (4W).  PT(PORT_2) says 15W, and PAE says 72.5% Efficient. The math for PAE just doesn't match the numbers. This is a bug, either in my understanding or in the program---I'm just not sure which.
    I'm not sure what to do next, any help would be greatly appreciated!
    -Eric
