  2. RF Design
  3. Interstage matching in Cadence Virtuoso
  • Subscribers 63
  • Views 20741
sidt
sidt over 5 years ago
I am trying to create a multistage amplifier operating around 200 GHz in Cadence Virtuoso. Could someone tell me how I can measure the impedances at intermediate nodes? I need this so that I can do conjugate matching between stages.
In the past, I have designed amplifiers using ADS. I used 'SP probe' between the stages to measure impedances. Is there something similar in Cadence Virtuoso?
I read something about 'sprobe' in cadence forums. I think I need to use that block. But unfortunately, I could not find it in my analogLib. Has it been added recently? Or am I missing something? (I'm using IC617)
Thanks.
    ShawnLogan over 5 years ago +1
    Dear sidt, sidt said: read something about 'sprobe' in cadence forums. I think I need to use that block. But unfortunately, I could not find it in my analogLib. Has it been added recently? Or am I missing…
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to sidt +1
    You can build an sprobe yourself if you want, see edadocs.software.keysight.com/.../viewpage.action
  • Tawna
    Tawna over 5 years ago in reply to ShawnLogan +1
    Hello sidt Definitely upgrade your version of software. You're using a very old version of code. The sprobe is pretty easy to use. My article walks you through it step by step. Article (20472560…
    Dear sidt,
    If I understand your question, I believe this document will help understand its use in finding an interstage impedance for use in matching.
    support.cadence.com/.../ArticleAttachmentPortal
    Have you examined this? The note indicates the following:
    "The sprobe was introduced in IC617 ISR15, ICADV12.3 ISR15 and Spectre 16.1 ISR8."
    Hence, if your installation is earlier than ISR15, it will not be in the analogLib.
    Shawn
  • sidt
    sidt over 5 years ago in reply to ShawnLogan
    Dear ShawnLogan,
    Thank you for your answer. I am using ISR4. That's why I don't have the sprobe component.
    - Sidt
  • Frank Wiedmann
  • Tawna
    Hello sidt
    Article (20472560) Title: Using the Spectre sprobe to measure impedance/stability in impedance matching networks and multi-stage designs
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006Ak2KUAS
    We've also made quite a few improvements to the analogLib nport in IC618ISR9/ICADVM181ISR9 and later.   You can now plot immittance (as well as impedance and admittance) on the Smith Chart.
    Many great things in IC6.1.8/ICADVM18.1/ICADVM20.1!
    Best regards,
    Tawna
  • sidt
    sidt over 5 years ago in reply to Tawna
    Hi Tawna,
    Thanks for the reply. I upgraded to IC618 and spectre 19. I now have access to sprobe.
  • sidt
    sidt over 5 years ago in reply to Frank Wiedmann
    Thanks. This is interesting.
