  2. RF Design
  3. multiple S-parameter Simulation touchstone save
  • Subscribers 63
  • Views 21417
amirbrad
amirbrad over 5 years ago
Hi
I want to do an S-parameter simulation and sweep a design variable in ADE XL setup and save each S-parameter results in a separated touchstone file
But when I give an address in Output Parameter 'file' field, it just saves last simulation result in sweep
I don't know how can save all results
    Presumably you've giving a full path. Rather than doing that, give a file name without the path component, and then it will get saved in the netlist directory for each sweep point. That's the simplest way of doing this.
  • amirbrad
    amirbrad over 5 years ago in reply to Andrew Beckett
    Thanks for your attention Andrew,
    It saves touchstone in netlist directory for single run
    But when I do it in ADE XL, the touchstone file goes to sharedData  directory, and updates at each simulation. finally I have the last step result
    Andrew Beckett over 5 years ago in reply to amirbrad
    That seems a bit strange to me - even if you've turned on some of the environment variables which would result in the netlist file being shared, I don't think the sp file should end up being shared.
    Which sharedData directory are you talking about? Can. you please let me know the full path to that, and also the IC and spectre sub-versions that you're using?
    If you make the output file "../psf/file.s2p" or similar, does that help (i.e. in the psf dir instead)?
  • amirbrad
    IC6.1.6-65b.500.9
    ../adexl/results/data/Interactive.0/sharedData/Job20/ahdl/input.ahdlSimDB
    "../psf/file.s2p" didn't work
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to amirbrad
    I suggest you take a look at support.cadence.com/.../ArticleAttachmentPortal
  • Tawna
    Tawna over 5 years ago in reply to amirbrad
    Hi amirbrad,
    I recommend filing a Case with Cadence Online Support https://support.cadence.com .   That way an AE can walk through this with you and give suggestions (and file a CCR if necessary).   We answer questions on the forum after our "day job".   This seems like a weird error.
