  2. RF Design
  3. Unable to run cds_srr commands in matlab
  • Subscribers 63
  • Views 15170
findsriharsha
findsriharsha over 5 years ago
Here is my simple matlab script:
import cadence.srrdata.*
import cadence.Query.*
import cadence.utils.*
resdir = '/nfs/sc/disks/xyz_dts_tb/maestro/results/maestro/Interactive.47/1/xyz_noise/psf';
datasets = cds_srr(resdir);
Here is the error:
Matlab default startup completed.
Running Intel workaround to prevent >200MB disk usage in your home directory.
Done.
>> spectre_matlab1
Invalid MEX-file '/p/hdk/cad/mmsim/19.1.0.561/tools/spectre/matlab/64bit/cds_innersrr.mexa64': /nfs/site/disks/hdk_cad_3/cad/matlab/R2016a/bin/glnxa64/../../sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by
/p/hdk/cad/mmsim/19.1.0.561/tools/spectre/matlab/64bit/../../../lib/64bit/libsrr.so)
Error in cds_srr (line 16)
sig = cds_innersrr(dirname);
Error in spectre_matlab1 (line 7)
Matlab Env:
MATLAB=/nfs/site/disks/hdk_cad_3/cad/matlab/R2016a
BASEMATLABPATH=/p/hdk/cad/mmsim/19.1.0.561/tools/spectre/matlab/64bit:/p/hdk/cad/mmsim/19.1.0.561/tools/spectre/matlab/:/nfs/sc/disks/axx_0419/sriharsh/1276_vmac/vmac_dts_21ww03p5a/matlab:/p/hdk/cad/analog_collateral/18.14.2/libraries/matlab/
OSG_LD_LIBRARY_PATH=/nfs/site/disks/hdk_cad_3/cad/matlab/R2016a/sys/openscenegraph/lib/glnxa64
    You need to have closer alignment between the MATLAB and Spectre versions. You're using Spectre from 2019 and MATLAB from 2016. Because the cds_srr stuff uses a shared library, there's a requirement to use aligned compiler versions.
    I reproduced the same issue you did running on my RHEL7.6 machine, using the same version combinations. If I use MATLAB R2020a with SPECTRE19.1 then it works fine. Also if I used MATLAB R2016a with SPECTRE16.1 it also worked OK (I didn't check the range of working versions - there is a support matrix in the documentation and on support.cadence.com if I remember rightly).
  • Tawna
    Tawna over 5 years ago
    MMSIM Spectre, APS, SpectreRF and Matlab support matrix  is the Article that Andrew is talking about.
    best regards,
    Tawna
