  2. RF Design
  3. Error When trying to Import the subcircuit Spice model into...
  • Replies 9
  • Subscribers 63
  • Views 26407
Error When trying to Import the subcircuit Spice model into Cadence
MattNEU
MattNEU over 5 years ago
Hope you are doing fine. I have read the forum and the post Tawna made here: https://community.cadence.com/cadence_blogs_8/b/rf/posts/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade
I tried to import the Spice model into the Cadence based on that instructions but I cannot follow from the third step as it is totally different in my Cadence version probably. But I got the idea from the instructions and created a spiceText cellview, then saved it and it automatically created the symbol for me based on the pins and terminals. Then I am trying to use this symbol in another schematic to do some SP analysis in schematic. But, at the very first point I get the error for creating the netlist, so do you have any suggestion how can I import this amplifier spice model into my library (I have also attached my CDF menu screen shot which is different from what is mentioned in the instructions by Tawna):
"generate netlist...
function ansCdlCompPrim redefined
Begin Incremental Netlisting Mar 22 16:34:00 2021
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'spectre veriloga ahdl cmos_sch schematic', for the
instance 'I0' in cell 'PAD115_tb'. Add one of these views to the cell 'PAD115' in the
library 'Non_Foster_Circuit', or modify the view list so that it contains an existing view.
End netlisting Mar 22 16:34:00 2021
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful."
  • Tawna
    Tawna over 5 years ago
    Hi Matt,
    That blog was written many years ago.  There's a more up-to-date version on Cadence Online Support FAQ: How to Include a Subcircuit (Netlist) into a Schematic and Simulate in ADE
    Do you have access to https://support.cadence.com ?
    What version of Virtuoso are you using?   This command (typed in a linux window) will give that information:
    virtuoso -W
    Tawna
  • MattNEU
    MattNEU over 5 years ago in reply to Tawna
    Tawna,
    Thanks for your quick reply. Unfortunately, I do not have access to the link and cadence community support. I have previously also contacted Cadence for getting the access but they mentioned only school liasons have the access, not the students.
    I am using 6.1.7.64b.500.18 version.
    Mehdi
  • Tawna
    Tawna over 5 years ago in reply to MattNEU
    Hi Matt,
    Sorry for the late reply.  Looks like I need to rewrite the blog.  :-)
    Your university should be able to connect you with the "university liason" (typically the professor) who can download the article for you.  The article is now written for IC6.1.8 and ICADVM 20.1 (so there may be some slight differences compared to IC6.1.7).
    You can also use the "SPICEIn" (virtuoso → File → Import → Spice) feature to import netlists and create schematics.  I believe that was available in IC6.1.7 (I don't remember).
    For me to assist, it would be helpful if you showed us your process step by step.  I may see something obvious that you are forgetting to do.
    Sorry, I'm taking off for the evening and won't be near my computer.
    best regards,
    Tawna
    Andrew Beckett over 5 years ago in reply to Tawna
    From the symptoms described, the most likely problem that the view name you gave the spectreText view you created is not included in the switch view list.
    So, assuming that the view name was "spectreText", go to Setup->Environment in ADE and for the "view list" field, add "spectreText" at the beginning of the list. This is the list of views to try when traversing the hierarchy.
    Using a spectre text view avoids the need to create a stopping view, or to need to edit the CDF using the approach covered in Tawna's blog. It also means you don't need to include the text of the subckt using the Setup->Model Libraries or Setup->Simulation Files, as the netlister will automatically reference the definition in the spectreText view.
  • MattNEU
    MattNEU over 5 years ago in reply to Andrew Beckett
    Thanks to both of you for your help. Our school liaison forwarded the instructions to me and it works fine, but I do have an error now:
    Error found by spectre during initial setup.
        ERROR (CMI-2078): spice: Required parameter `file' is missing.
    Andrew Beckett over 5 years ago in reply to MattNEU
    So is that error from when you ran the simulation? Did it give other error info that said which line of which file it had a problem with? Perhaps you could post the entire log file (you can attach files to the forum post)?
  • MattNEU
    Sure. Here is the whole log file for your reference, I have added the Spice model as well which is available online:
    This is the log file:
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 15.1.0.803.isr18 64bit -- 21 Jun 2017
    Copyright (C) 1989-2017 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: mehdina94rm   Host: 08vlab089   HostID: 5A0A5908   PID: 18430
    Memory  available: 170.6188 MB  physical: 16.8257 GB
    Linux   : CentOS Linux release 7.7.1908 (Core)
    CPU Type: Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
    All processors running at 2200.0 MHz
            Socket: Processors
            0:       0,  1
            1:       2,  3
    System load averages (1min, 5min, 15min) : 20.5 %, 14.2 %, 10.0 %
    This is a virtual machine
    Simulating `input.scs' on 08vlab089 at 4:39:14 PM, Tue Mar 23, 2021 (process id: 18430).
    Current working directory: /ECEnet/home/student/mehdina94rm/Sim/PAD115_tb/spectre/schematic/netlist
    Command line:
        /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools/bin/spectre  \
            -64 input.scs +escchars +log ../psf/spectre.out -format psfxl  \
            -raw ../psf +lqtimeout 900 -maxw 5 -maxn 5
    Loading /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Loading /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
    Loading /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
    Loading /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
    Loading /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
    Reading file:  /ECEnet/home/student/mehdina94rm/Sim/PAD115_tb/spectre/schematic/netlist/input.scs
    Reading file:  /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/spectre.cfg
    Reading file:  /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/mapsubckt.cfg
    Reading file:  /Users/Grad/mehdina94rm/Desktop/PAD115.ckt
    Time for NDB Parsing: CPU = 150.786 ms, elapsed = 333.993 ms.
    Time accumulated: CPU = 204.021 ms, elapsed = 334.006 ms.
    Peak resident memory used = 38.1 Mbytes.
    The CPU load for active processors is :
            Spectre  0 (18.8 %)      1 (63.6 %)      2 (18.8 %)      3 (18.8 %)
            Other
    Reading link:  /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading file:  /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading link:  /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file:  /ECEnet/Apps1/linux/cad12/tools/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/constants.vams
    Warning from spectre in `PAD115':`I0', during hierarchy flattening.
        WARNING (SFE-30): "/Users/Grad/mehdina94rm/Desktop/PAD115.ckt" 125: I0.JA: `NR' is not a valid parameter for an instance of `jfet'.  Ignored.
        WARNING (SFE-30): "/Users/Grad/mehdina94rm/Desktop/PAD115.ckt" 125: I0.JA: `VK' is not a valid parameter for an instance of `jfet'.  Ignored.
    Time for Elaboration: CPU = 42.777 ms, elapsed = 62.3231 ms.
    Time accumulated: CPU = 247.213 ms, elapsed = 396.742 ms.
    Peak resident memory used = 44.3 Mbytes.
    Warning from spectre during hierarchy flattening.
        WARNING (CMI-2049): I0.QP1: Value of `ikr' should be greater than zero.  Ignored.
    Time for EDB Visiting: CPU = 4.287 ms, elapsed = 5.48005 ms.
    Time accumulated: CPU = 251.877 ms, elapsed = 402.598 ms.
    Peak resident memory used = 45.1 Mbytes.
    Warning from spectre during initial setup.
        WARNING (CMI-2318): I0.Q11: Parasitic resistor `rc' has been deleted because its value of 80 mOhm ( R / MFactor ) was smaller than `minr'.
        WARNING (CMI-2318): I0.Q11: Parasitic resistor `re' has been deleted because its value of 80 mOhm ( R / MFactor ) was smaller than `minr'.
        WARNING (CMI-2318): I0.Q10: Parasitic resistor `rc' has been deleted because its value of 80 mOhm ( R / MFactor ) was smaller than `minr'.
        WARNING (CMI-2318): I0.Q10: Parasitic resistor `re' has been deleted because its value of 80 mOhm ( R / MFactor ) was smaller than `minr'.
        WARNING (CMI-2318): I0.Q9: Parasitic resistor `rc' has been deleted because its value of 80 mOhm ( R / MFactor ) was smaller than `minr'.
            Further occurrences of this warning will be suppressed.
        WARNING (CMI-2316): I0.X5.D3: Parasitic resistor `rs' has been deleted because its value of 3 uOhm ( R / (Area * MFactor) ) was smaller than `minr'.
        WARNING (CMI-2316): I0.X4.DSD: Parasitic resistor `rs' has been deleted because its value of 11.5 mOhm ( R / (Area * MFactor) ) was smaller than `minr'.
        WARNING (CMI-2316): I0.X3.DSD: Parasitic resistor `rs' has been deleted because its value of 11.5 mOhm ( R / (Area * MFactor) ) was smaller than `minr'.
    Notice from spectre during initial setup.
        I0.X5.MM: Default value for `uo' is used.
        I0.X5.MM: Values of `kp' and `uo' are not consistent.
        I0.X3.DMOS: Default value for `uo' is used.
        I0.X3.DMOS: Values of `kp' and `uo' are not consistent.
        I0.X3.DMOS: `cgso' is not specified.  0.1um * Cox is used.
        I0.X3.DMOS: `cgdo' is not specified.  0.1um * Cox is used.
    Aggregate audit (4:39:14 PM, Tue Mar 23, 2021):
    Time used: CPU = 255 ms, elapsed = 406 ms, util. = 62.8%.
    Time spent in licensing: elapsed = 36.3 ms, percentage of total = 8.95%.
    Peak memory used = 45.6 Mbytes.
    Simulation started at: 4:39:14 PM, Tue Mar 23, 2021, ended at: 4:39:14 PM, Tue Mar 23, 2021, with elapsed time (wall clock): 406 ms.
    spectre completes with 1 error, 16 warnings, and 6 notices.
    spectre terminated prematurely due to fatal error.
    Spice Model:
    * POWER AMP DESIGN PAD115 High Voltage High Power Op Amp
    *Note: Operational amplifiers are often difficult to converge in SPICE
    *because of the high gain of the amplifier. To assist convergence it
    *is often helpful to nodeset the -IN node and the OUT node to the voltage
    *expected. Also, it is helpful to set options for ITL1 to 10000, ITL2 to 2500
    *and ITL4 to 2500.
    *Note: shutdown function and temperature output are not simulated.
    *Note: Vcc is connected to +Vs, -Vcc is connected to -Vs
    *V1.1 Oct 9 2006
    simulator lang=spice
    spice macro subckt netlist
      *                         -IN +IN CC1 CC2 +VS -VS  OUT
    .SUBCKT PAD115    1     2     3       4       5      6      10
    *** CONTENT REMOVED BY MODERATOR TO AVOID DISCLOSING COPYRIGHTED/PROPRIETARY INFORMATION
     .ENDS
    ShawnLogan over 5 years ago in reply to MattNEU
    Dear MattNEU,
    1. Perhaps it my misunderstanding of your post, but you've included the following line in your SPICE model file:
    but it is not the first line in the file. I am not sure - Andrew will know - but I do not believe spectre recognizes the SPICE comment character as a comment. Since it is not the first line, this may cause a problem when spectre reads in the file.
    Did you try placing the line "simulator lang=spice" as the very first line of the file?
    2. How and where did you include the path to your spice model file? You need to include the full pathname and enclose it in double-quotes. The most typical place to include it is in your Model file setup GUI.
    Shawn
    I removed the content of the SPICE Model above because it was not clear that you were allowed to post it in a public forum (it said it contained proprietary information, so it would have been better to reference where it was published elsewhere rather than posting the file here in case you're breaking copyright).
    Anyway, the issue is due to this line:
    That''s not a valid SPICE line, and so you should put a "*" at the beginning of the line to make it a comment. If you do that, it will proceed without the error.
    To answer 's concern, Spectre also copes with the SPICE comment syntax of using * at the beginning of a line, so the simulator lang doesn't need to be at the beginning. Anyway, the file appears to have a suffix of ".ckt" so would have been treated as SPICE syntax anyway, so the simulator lang=spice is superfluous.
