  2. RF Design
  3. Question about DC convergence error in sweep simulation...
  • Replies 12
  • Subscribers 63
  • Views 23936
dskang
dskang over 5 years ago
Hello, thank you in advance for your assistance.
I was making simple op-amp, but I used verilog-a based mosfet model (MIT-VS model).
To see DC operating point, I did DC simulation, and it seemed like the values settled on wrong point. (Results were not reasonable.)
However, when I did sweep simulation (sweep variable was temperature, which should be almost non-relative to the results), I found DC convergence result goes to correctly as simulations goes on. - This is also weird and I couldn't understand.
However, as dcOp still gives not reasonable values, so I cannot do other simulations like measuring AC gain.
I've already used nodeset, but it didn't worked.
Could anyone give me the solution how to apply dcOp to points that were gathered through sweep simulation, or to get appropriate DC results from the beginning?
Thank you so much
Best,
Dongsuk
    Hi Dongsuk, It's extraordinarily rare for Spectre to produce an "incorrect" DC operating point (so rare, I can't remembering it ever happening). It's possible however that the operating point is perfectly…
    ShawnLogan over 5 years ago +1
    Dear Dongsuk, > To see DC operating point, I did DC simulation, and it seemed like the values settled on wrong point. (Results were not reasonable.) > > However, when I did sweep simulation (sweep…
    ShawnLogan over 5 years ago in reply to dskang +1
    Dear Dongsuk, dskang said: I used nodeset first but it didn't worked, and after that I changed to writefinal -> readfile way and it somehow worked. Seems like this way is setting initial condition. …
  • dskang
    dskang over 5 years ago in reply to ShawnLogan
    Dear Shawn,
    Thank you for answering my question. Now I understand some degree how to handle this problem. It's lucky that I could find solution, even it is not 100% orthodox - like fixing code.
    Your advice helped me a lot. Thank you again:)
    Dongsuk
    Dear Dongsuk,
    You are most welcome - but I am just happy to read that you have a better understanding and have some time of solution to your problem! Thank you for letting Andrew and I know!
    Shawn
