  2. RF Design
  3. HB AC warnings: Solver did not converge to the desired tolerance...
  • Replies 7
  • Subscribers 63
  • Views 17022
HB AC warnings: Solver did not converge to the desired tolerance of 0.0001
Sjrg
Sjrg over 5 years ago
I have been getting the following errors in my HB AC simulations. Would like to get some feedback on how to solve this.
Warning: Solver did not converge to the desired tolerance of 0.0001. It converged to 1. The solution may not be accurate but it's saved anyway.
hbac: freq = 23.1 GHz (1.25 %), step = 100 MHz (1.25 %)
Warning: Solver did not converge to the desired tolerance of 0.0001. It converged to 9.62543e-06. The solution may not be accurate but it's saved anyway.
hbac: freq = 23.2 GHz (2.5 %), step = 100 MHz (1.25 %)
Warning: Solver did not converge to the desired tolerance of 0.0001. It converged to 1.53487e-05. The solution may not be accurate but it's saved anyway.
hbac: freq = 23.3 GHz (3.75 %), step = 100 MHz (1.25 %)
Warning: Solver did not converge to the desired tolerance of 0.0001. It converged to 1.13937e-05. The solution may not be accurate but it's saved anyway.
hbac: freq = 23.4 GHz (5 %), step = 100 MHz (1.25 %)
hbac: freq = 23.5 GHz (6.25 %), step = 100 MHz (1.25 %)
Let me know if you need any further info on this.
SJRG
    Which spectre version are you using?
    Andrew Beckett over 5 years ago in reply to Andrew Beckett
    BTW, the reason your post went into moderation was the repeated text - this triggers the spam detection. It's clearly not spam, but the automated forum software doesn't know that.
  • Sjrg
    Sjrg over 5 years ago in reply to Andrew Beckett
    Noted. Thanks for the feedback
  • Sjrg
    Spectre version: mmsim60_isr21
    Andrew Beckett over 5 years ago in reply to Sjrg
    Really? You're using a simulator version from 15-16 years ago?
    I thought the message wasn't current - there's an article which talks about a newer version of the message here: HB small signal analyses gives GMRES stagnation or convergence warnings. but this should be extremely rare nowadays. You're using the very first version of Spectre that had harmonic balance support, and there have been huge numbers of advances since then.
    Actually you can't be using that, because there was no hbac in that release - I just checked... but I suspect you're using something old nevertheless.
  • Sjrg
    You're right. I'm infact using mmsim201_isr1
    In that case, you should follow the advice in the article I pointed to - which is to contact customer support.
