  2. RF Design
  3. expression vs OS param problem
  • Subscribers 63
  • Views 15026
robert 21
robert 21 over 5 years ago
Hello,I have tried to build an expression of ft vs gm as shown bellow,by defining on side by name then i have did wavevswave in calcularor.
It shows me the error shown in the end.
Where did i go wrong?
Thanks.
    ShawnLogan over 5 years ago +1
    Dear robert21, robert 21 said: It shows me the error shown in the end. Where did i go wrong? I believe you may not have defined the second waveform argument as gmoverid. The interpreter is considering…
    Dear robert21,
    I believe you may not have defined the second waveform argument as gmoverid. The interpreter is considering the name you used as a variable and does not recognize it as a waveform.
    The waveVsWave() function requires, as a minimum, two waveforms as its arguments and from the error you are reporting, it appears you have not defined gmoverid as a waveform. You defined the output expression OS("/NM0" "gmoverid"), but did you give it the name gmoverid?
    Shawn
  • robert 21
    robert 21 over 5 years ago in reply to ShawnLogan
    Thank you very much
    ShawnLogan over 5 years ago in reply to robert 21
    Dear robert21,
    Thank YOU for letting me know! I am just happy it was of some help robert21.
    Good luck!
    Shawn
