  2. RF Design
  3. bbspice process failed
  • Subscribers 63
  • Views 15412
fastandig
fastandig over 5 years ago
I searched this and the RF forum, but couldn't find a discussion on this issue before. I am simulating a VCO test-bench with inductors extracted using EMX. I have the s-parameter file path entered as a variable for the n-port. When I start the simulation I get this error at the start almost immediately:
Error found by spectre during initial setup.
      ERROR (NPORT-1022): Generate lock-file for bbspice process failed.
Interestingly, when I simulate just the inductor n-port by itself with the same s-parameter file as above to get the Q and L, the simulation runs smoothly and I get the expected result. Another thing is that there are some older s-parameter files from last year that run perfectly fine with the above VCO test-bench. I'm not really sure what the problem is so would greatly appreciate some help. Thank you.
EDIT: If I change the n-port interpolation method to linear or spline the whole test bench simulation runs fine, but I would like to use bbspice for more accurate results.
  • Tawna
    Tawna over 4 years ago
    Please download and review the AppNote: 7 Habits of Highly Successful S-Parameters (Spectre 20.1, 19.1 and IC6.1.8 ISR9) from https://support.cadence.com.
    This goes into great detail about how to be successful simulating s-parameters in Spectre.  Typically we recommend you use the default interpolation method and let Spectre choose the interpolation method based on the analysis being run (there are exceptions to this - all discussed in the appNote).   Saying "would like to use bbspice for more accurate results" is not always an accurate statement.  :-)
    Now about this error...
    I've seen this error happen when the user's disk quota is exceeded (the user deleted the contents under the ~/.cadence/mmsim/ directory to resolve the issue).
    I've also seen the error when the permissions didn't allow data to be written to ~/.cadence/mmsim
    You can try the following.  Go to:  Simulation - Options - Analog, and on the Component tab set "nportirreuse" to "no".   And re-run the simulation.   Typically we *want* nportirreuse set to yes, as described in the appNote.
    best regards,
    Tawna
  • fastandig
    fastandig over 4 years ago in reply to Tawna
    I found the problem. File path of a different user was specified under "nportirfiledir" because I had copied the test-bench. Once I removed the path, bbspice ran just fine.
