  2. RF Design
  3. [EMX] Parametric sweep pcell
  • Subscribers 64
  • Views 14266
Miyakuzi
Miyakuzi over 4 years ago
Hey,
Is there a way in EMX to do a parametric sweep of a pcell. Let's say I have an inductor, and I want to sweep the diameter. This diameter I'll give the name 'D' in the layout pcell parameter. In the EMX setup, is there a way to sweep this parameter and perform an EM-Simulation for each point and save the results? Thus potentially using these simulations in the symbol of the inductor in a schematic view with the same parameter 'D', thus when running a schematic simulation, all you would have to do is change the parameter 'D' in the schematic, and the corresponding s-parameter file would be used in the schematic simulations.
Kind regards
    You should contact customer support or your account team. This sounds closer to the former Integrand product Continuum and so we would need to have a discussion about precisely what you want and what would be the best solution.
  • gvidasra
    gvidasra over 4 years ago
    I am also interested in this question.
    What I found for EMX, that it is possible to simulate the matrix of inductors. You will get sNp file = P1+P2 * size_of_matrix.
    Trick is to make good TB for extracting L,Q,R values of separated inductors.
