  2. RF Design
  3. Doing a swept simulation and for each simulated point save...
  • Subscribers 63
  • Views 13084
Doing a swept simulation and for each simulated point save the snp
TommasoF
TommasoF over 4 years ago
Hello everybody,
in a "sp" simulation there is the possibility to save the corresponding s2p in a file. If one enters a VAR (variable), he can also parametrize the corresponding file name.
On my testbench I create  several corners where each has a different content for the variable "output_file". Let's say
  • in "corner_v1" --> output_file="mysnp_v1.s2p"
  • in "corner_v2" --> output_file="mysnp_v2.s2p"
  • and so on...
when I run a sp simulation among 3 corners I get 3 snp files stored on the local folder. Each file correspond to a given corner.
To simplify the workload on my side, instead of creating corners, Is it possible to perform a variable sweep let's say from 0:1:10 and create 11 s2p files where each file is named with the corresponding index ? (e.g. "mysnp_0.s2p", "mysnp_1.s2p", "mysnp_2.s2p", ...,  "mysnp_10.s2p")
Tommaso
    Tommaso,
    Assuming you're using ADE Explorer or Assembler, create a variable (say) "n", and your output_file variable with a SKILL expression (e.g. using lsprintf) as follows:
    n: 0:1:10
    output_file: lsprintf("mysnp_v%n.s2p" VAR("n"))
    This will do what you want.
  • TommasoF
    TommasoF over 4 years ago in reply to Andrew Beckett
    thank you Andrew, that works perfectly!
