  2. RF Design
  3. PSS does not converge if initial condition is set
  • Subscribers 63
  • Views 19034
jandk
jandk over 4 years ago
  When I simulate a divider as shown in the circuit diagram below, I find that if I don't give the initial state of the circuit shown in the diagram, the circuit doesn't achieve its function("1"  for high voltage 1.2V, "0" for gnd 0V). I set the initial condition in ADE simulation>>convergence aids>>initial condition. The problem is that if I set the initial condition, PSS does not converge and if I don't set the initial condition, the PSS converges but the circuit does not work(circuit nodes do not see any level changes).  And I find that Conv norm keeps the value of 606e+03 constant. So how do I set it up to make the PSS converge?
Look forward to your reply.
    The convergence problem is probably that you don't have the PSS fundamental frequency set correctly, or that you didn't give a long enough time for the tstab to ensure the divider is correctly working. I don't quite see from the above what the circuit is supposed to be doing (since it appears to be a shift register rather than a divider. If it's a divider, did you set the PSS frequency to the divided down frequency (rather than the input frequency)? Are there any even lower frequencies in the circuit (sub-harmonics)? If so, your PSS fundamental needs to reflect that as all frequencies in the circuit need to be an integer multiple of the PSS fundamental.
  • jandk
    jandk over 4 years ago in reply to Andrew Beckett
    That right! You have pointed out the problem that I didn't notice the lowest frequency was changed to one eighth of the original frequency. Thank you very much!
    ShawnLogan over 4 years ago in reply to jandk
    Dear jandk,
    I fear a second issue may be that without your initial condition, the circuit (which appears to be a divider), is that the circuit will not function unless you ensure the output of one flip-flop has a different state than the remaining flip-flop outputs. For example if all outputs come up in the logic low state, as the input clock advances, all the flip-flops will remain in the logic low state and hence will not form a divide-by-8 of the input clock frequency.
    Shawn
  • jandk
    jandk over 4 years ago in reply to ShawnLogan
    That's right. If I don't give the initial logic state, all nodes will keep the same voltage level all the time.
