  2. RF Design
  3. Regarding User Guide
  • Subscribers 63
  • Views 10168
Gabru
Gabru over 3 years ago
I wanted to get "Virtuoso® Spectre® Circuit Simulator and Accelerated Parallel Simulator RF Analysis User Guide".
Where I can find this guide in my installation directory?
Regards
Arpit
    Andrew Beckett over 3 years ago +1
    Arpit, You can either use <SPECTREinstDir>/bin/cdnshelp and then you can find it within cdnshelp (you can then open the PDF too), or you can just look at <SPECTREinstDir>/doc/spectreuser/spectreuser…
    Arpit,
    You can either use <SPECTREinstDir>/bin/cdnshelp and then you can find it within cdnshelp (you can then open the PDF too), or you can just look at <SPECTREinstDir>/doc/spectreuser/spectreuser.pdf
  • Gabru
    Gabru over 3 years ago in reply to Andrew Beckett
    Thanks for the reply,
    I found it.
