  2. RF Design
  3. How to substract bussed analog signals ?
  • Subscribers 63
  • Views 10338
Guillaume H
Guillaume H over 3 years ago
I am facing the following issue with Maestro Assembler / Explorer.
- Output # 1 is [ Test_1 = vtime('tran "/RFFE/HPPA/CORE/CHANNEL<3>/lo_pmos_msb<30:0>") ]. This is actually a bus of 31 analog waveforms. This output is correctly evaluated by Assembler.
- Output # 2 is [ Test_2 = vtime('tran "/RFFE/HPPA/CORE/CHANNEL<3>/MSB<30:0>/local_vss") ]. This is again a bus of 31 analog waveforms, which evaluates correctly.
All waveforms are from the same transient simulation : They share the same time-points.
Now, If I declare a third output as [ Test_3 = Test_1 - Test_2 ], I would expect Test_3 to be a bus of 31 waveforms with [ Test_3<i> = Test_1<i> - Test_2<i>, ], but it fails to evaluate.
Any idea to solve this ?
/Guillaume
  • Guillaume H
    Edit : It works when one of the bus is replaced by a single waveform.
    /Guillaume.
  • Guillaume H
    Forgot to mention : getVersion(t) -> "sub-version ICADVM20.1-64b.500.29 "
    /Guillaume
    Andrew Beckett over 3 years ago in reply to Guillaume H
    Hi Guillaume,
    The trick is to use the function in this article of mine - it explains why this is a challenge and provides a function to adapt the bus-indexed waveforms so that you can do operations that work on buses of different signals: How can I measure the delay between each bit of two analog buses in the ViVA calculator? (the title may not be obvious that it's related - perhaps I should try to generalise the title).
  • Guillaume H
    Guillaume H over 3 years ago in reply to Andrew Beckett
    It works perfectly. Thanks a lot !
    However, I still have some trouble with the result of [ abBusToIndex(BusP<2:0>)-abBusToIndex(BusN<2:0>) ].
    Let me explain. Please consider the following outputs :
    • Test0 = vtime('tran "/lo_pmos_msb<2:0>")
    • Test1 = (abBusToIndex(vtime('tran "/lo_pmos_msb<2:0>")) - abBusToIndex(vtime('tran "/MSB<2:0>/local_vss")))
    • Test2 = (abBusToIndex(vtime('tran "/lo_pmos_msb<2:0>") t) - abBusToIndex(vtime('tran "/MSB<2:0>/local_vss") t))
    • Test3_p = abBusToIndex(vtime('tran "/lo_pmos_msb<2:0>"))
    • Test3_m = abBusToIndex(vtime('tran "/MSB<2:0>/local_vss"))
    • Test3_p_m = Test3_p - Test3_m
    • Test4_p = abBusToIndex(vtime('tran "/lo_pmos_msb<2:0>") t)
    • Test4_m = abBusToIndex(vtime('tran "/MSB<2:0>/local_vss") t)
    • Test4_p_m = Test4_p - Test4_m
    Note that :
    • Each of them should include 3 waveforms.
    • Test2 = Test1 but with [ abBusToIndex(vtime('tran "xxxxx"<2:0>")) ] replaced by [ abBusToIndex(vtime('tran "xxxxx"<2:0>") t) ]. Just a trial.
    • Same as point #2 above from [ Test3_* ] to [ Test4_* ]. Same trial.
    Then, please have a look at the screen-shot below and the following observations.
    • Test0 is 3 waveforms as expected, with each waveform perfectly identified. But no calculation can be made on it w.r.t. another bus, as already known.
    • Test1 and test2 seem (?) to be one waveform only ???
    • Test3_p and Test3_m are 3 waveforms as expected, but no clear information about which one is e.g. bit <2>.
    • Test3_p_m seems (?) to be one waveform only ???
    • Same for Test4_*. In other words, using the t) doesn't help.
    My questions :
    • Are the observation above correct ?
    • How to proceed to plot Tests 1* -> 4* as they should be ?
    I'm not familiar with the bitNum which appears only when using abBusToIndex(). There may be a 'dedicated' way to plot in such cases, but I couldn't find info on it.
    Thanks.
    /Guillaume
