  2. RF Design
  3. RE : calculating the output power of a Quartz oscillato...
  • Replies 32
  • Subscribers 64
  • Views 28042
RE : calculating the output power of a Quartz oscillator
david j james
david j james over 3 years ago
Help !
I am designing a Crystal Oscillator ( which is a complex load) and trying to calculate Output power (to avoid over loading the crystal). I am using pss to simulate it and I get a tran waveform.
The power is complex so it is not easy to calculate. For example in a transient simulation phase information isn't readily available.
When I create calculations in calculator tool  get several different answers, and I am not sure which to trust
How should I calculate the output power?
What is the 'recommended' method?
  • david j james
    david j james over 3 years ago in reply to ShawnLogan
    1. I am looking at a range of crystals in the 10 -50MHz range. They all quote 10pF or more Shunt Caps values.
    2. For Input Capacitance I made the following rough estimate :
    • External Shunt caps : 2 x 10pF
    • Amplifier Input/output Capacitances : 2 x 2pF ( allowing for pads, PCB, ESD etc )
    • Total : 24pF
    • Does this sound right or silly?
    3. Again you are right. I didn't read the excel carefully. The voltage on the pin is sinusoidal rail to rail.
  • david j james
    The tool generates a spectrum with a single tone at 10MHz. I use the ymax function simply to get the magnitude of this tone. The rms calculator function doesn't work on this waveform.
    The crystal Datasheets we have looked at, all quote 'Drive Level ( maximum)'. No mention of rms.
    The oscillator is a Pierce type : like below but Ro is not used.
  • Tawna
    Tawna over 3 years ago in reply to david j james
    We strongly recommend using the hb interface.  It has all the "latest and greatest" features.   Two articles that I suggest you download and read from https://support.cadence.com are:
    Getting the Most Out of Spectre® X-RF 21.1: Maximizing Performance
    How to simulate a high Q (LC or crystal) oscillator followed by strongly nonlinear circuitry (e.g. hard switching buffers)
    If you are a university student, please contact your professor (or Cadence contact at your university) and ask him to download these for you.
    best regards,
    Tawna
    ShawnLogan over 3 years ago in reply to david j james
    Dear david j james,
    I would suggest you run a simple testcase where you apply a sinusoidal volatge across a resistor to determine if the peak value of the power represents an rms or peak power. If the spectruma relies on the Cadence dft(), it does not natively produce the rms value as its maximum. I have documented this and reported it.
    The maximum power dissipation is measured using the rms current. Please see, for example, the following two vendors suggestions for measuring power - both specify using the rms current. From a physics perspective, the peak power is not the important parameter but rather the rrns "heating" power. The latter impacts quartz resonator drive level effects and reliability (aging drift for example).
    q-tech.com/wp-content/uploads/QTAN108-Crystal-Current-Measurement.pdf
    www.renesas.com/us/en/document/apn/830-quartz-crystal-drive-level
    I am sorry, but unless I am overlooking your Pierce schematic design, it does not show me how you voltage source is set up to measure power.
    Shawn
  • Tawna
    When simulating high Q oscillators, set errpreset=conservative always.   hb accuracy depends more on harmonics.  pss accuracy depends more on errpreset.    These questions are answered in articles on https://support.cadence.com .  Do you have access?
    Dear david j james,
    Thank you for the added and helpful information! A comment or two follow if I may  - and you have the patience with me!
    I understand. The shunt capacitance specified, 10 pf in your example, specifies the load capacitance where the oscillation frequency will be exactly the specified quartz crystal unit frequency at the specified temperature. Hence, if the accuracy of your output frequency is critical (less than say 50 - 100 ppm from the 10 - 50 MHz crystal unit's frequency), it is important that the total load capacitance the terminals of the crystal unit is the specified load capacitance - or 10 pf in the example you provided.
    • Total : 24pF
    The effective load capacitance in the Pierce topology is composed of the total capacitance consisting of the parallel combination of the values of C1 and C2 you show in a later Forum post plus your board stray capacitance(s) plus your amplifier input capacitance. I've put together a view of the relevant "equivalent" board and amplifier capacitances and the equivalent load capacitance seen by the terminals of the quartz crystal unit as Figure 1. I hope this helps!
    Shawn
    Figure 1
    ShawnLogan over 3 years ago in reply to ShawnLogan
    Sorry, I just looked at Figure 1 and realized I made an error! The corrected version is shown below.
    Shawn
  • david j james
    Firstly, sorry for the slow response cased by meetings at work. Thanks for your valuable support.
    1. The testcase with a sinusoidal voltage (1V peak) across a 100 Ohm resistor gives hb = 5mW. Pout = V^2/R = 1^2/100 = 10mW. I have to think about where the x2 comes from, but I agree with you hb is giving MAXIMUM, not rms values.
    2. the Quartz suppliers we looked at ( eg NDK), quote maximum drive. This has been confirmed with their rep.
    3. the schematic I am using is this : bondwires, external caps with esr. the port and cds block are for stability sims. the 0V vdc used to measure power is called 'V_xosc'. The driver ( not shown ) is a simple Inverter.
  • david j james
    OK, so using that calculation in my application :
    • Amplifier Input Capacitances : 2pF ( allowing for pads, ESD etc )
    • PCB Capacitance : 3pF ( worst case)
    • Total : 11pF
    • so gives Operating Power Dissipation = 6.3uW.
    Dear david j james,
    Please check your calculation, as I think the power of a 1 V amplitude sinusoid (2 Vpp) across a 100 ohm resistor is:
    I'm not going to disagree, but the issue at hand is that the maximum drive refers to the rms power and not the peak power. From NDK's site:
    reference:
    Thank you for the schematic! I now understand that you are measuring the current through only the quartz crystal unit.
    Shawn
