  2. RF Design
  3. RE : calculating the output power of a Quartz oscillato...
  • Replies 32
  • Subscribers 64
  • Views 28064
RE : calculating the output power of a Quartz oscillator
david j james
david j james over 3 years ago
Help !
I am designing a Crystal Oscillator ( which is a complex load) and trying to calculate Output power (to avoid over loading the crystal). I am using pss to simulate it and I get a tran waveform.
The power is complex so it is not easy to calculate. For example in a transient simulation phase information isn't readily available.
When I create calculations in calculator tool  get several different answers, and I am not sure which to trust
How should I calculate the output power?
What is the 'recommended' method?
  • david j james
    david j james over 3 years ago in reply to ShawnLogan
    Ok, thanks for the good support. This seems to clear up my issues.
    ShawnLogan over 3 years ago in reply to david j james
    Dear david j james,
    Great! I am very happy to read you feel more comfortable with your results and thank you for letting us know. You put a lot of effort into your understanding and must be commended for that! Good luck!
    Shawn
