  2. RF Design
  3. What License is Required for Non-Linear Stability Analysis...
  • Subscribers 64
  • Views 9772
What License is Required for Non-Linear Stability Analysis in AWR Microwave Office 17?
Dhiman Sarkar
Dhiman Sarkar over 3 years ago
I'm trying to do a Non-Linear Stability Analysis in AWR MWO 17.
While plotting Input/Output Gamma using Gamma Probe (Closed Form): GPROBE2, getting an error saying .AP_HB:NLGAM_GP2(GPROBE2.GP1,1,50,0) : This measurement requires a license to run.
  • David Webster
    David Webster over 3 years ago +1
    Hi Dhiman, You need the STB-100 license for this measurement. First, in the AWR software I would go to File -> License -> Feature Setup. Then under Select Optional Features, check the box next to STB…
  • David Webster
    Hi Dhiman,
    First, in the AWR software I would go to File -> License -> Feature Setup. Then under Select Optional Features, check the box next to STB-100 and restart the software.
    If you don't see this checkbox, then I would go to https://www.cadence.com/en_US/home/tools/system-analysis/rf-microwave-design.html and scroll down to the "Contact Us" button and fill out the request form and someone will contact you.
    David W
  • Dhiman Sarkar
    Dhiman Sarkar over 3 years ago in reply to David Webster
    Thanks! Found the option to enable this feature.
