  2. RF Design
  3. Stabindex and S1/S2 in Sprobe Cadence
  • Subscribers 64
  • Views 6892
YufeiLiu
YufeiLiu over 1 year ago
I added Sprobe to the LNA I designed to check the stability of interstages. But the results generated by Sprobe confuse me.
For StabIndex, it is always less than 1. However, at some frequency, S1 and S2 will be greater than 1, and Z1 and Z2 will also have negative real impedance at that moment. I am wondering whether the circuit is in the unconditional stable state or unstable in this case?
Thanks!
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago
    I suggest that you take a look at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009lgsvEAA . It says that "StabIndex values below 1 are considered stable."
  • YufeiLiu
    YufeiLiu over 1 year ago in reply to Frank Wiedmann
    Thank you for your reply. I have read that article. Since for normal SP simulation with Ports, similar S11/S22 > 0dB or negative Z11/Z22(real) represent unstable situations. Just curious if it's possible to ignore S1/S2 >1 or negative real impedance in Z1/Z2 in Sprobes when Stabindex <1.
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago in reply to YufeiLiu
    The Spectre documentation does not seem to have a lot of information about the Stability Index. The AWR documentation has some more information under https://support.cadence.com/apex/techpubDocViewerPage?path=awrSimulationAnalysis/awrSimulationAnalysis24.1_ISR1/A.5._Stability_Analysis_Methods.html#A.5.StabilityAnalysisMethods-A.5.4.MicrowaveOfficeApproachtoInternalStabilityAnalysis . If we assume that Spectre is using the same definition, a Stability Index < 1 at all frequencies (from 0 to infinity) would indeed mean that the circuit is stable according to the Nyquist Criterion.
