  2. RF Design
  3. 2 Tone Test of a LC-VCO and LDO: Best setup to get a reliable...
  • Subscribers 63
  • Views 6525
2 Tone Test of a LC-VCO and LDO: Best setup to get a reliable Phase Noise simulation
dtzlou
dtzlou over 1 year ago
Hi all,
I have an LC-VCO and an LDO with a very bad PSRR at frequency 250KHz (gain is positive!). I apply 20mV, 250KHz sinewave tone at the input of the LDO (VIN) and I want to check the PSRR impact on the VCO Phase Noise at this specific frequency 250KHz. The VCO frequency is 3GHz.
I am playing with HB + HBnoise setup but I am not 100% sure If i follow the correct setup in order to get accurate and meaningful results. Below you can see my HB and HBnoise setup settings:
HB Setup:
HBnoise Setup:
  • Do I need  to increase the Oversampling factor to get more accurate results?
  • Since I apply a sinewave tone at the input of the LDO, the harmonic number of this tone (the 2nd one) must be 1, right?
  • Do you recommend other simulation setup or this one is good enough to check the impact of the LDO modulation at the VCO Phase Noise
Thanks, kind regards
  • Tawna
    Tawna over 1 year ago
    Please file a Case with Customer Support at https://support.cadence.com .   An AE will be assigned to work with you on this.
    Best regards,
    Tawna Wilsey
