  2. RF Design
  3. Re: How to get all data from srrWave?
  • Subscribers 63
  • Views 3460
EA202509149412
EA202509149412 over 1 year ago
Hello! I designed a PA and performed load pull on it. In the obtained constant power contour plot, I want to extract the data of the constant power lines on the Smith chart. I can normally extract the required data (X, YRe, YReImag) using 'send to export'. I wish to extract this data through code.
I use the code
line = leafValue( cPwrContour(i("/I1/out" ?result "hb_fd" ) v("/net7" ?result "hb_fd") '1 ?refImp 50.0 ?numCont 11 ?modifier "dBm") "p" 9.4631312)
and get the reply from CIW that :
srrWave: 0x5d9b5de0
I want get data from this srrWave, I use the code
ocnPrint(line)
but I get the result data (X, |Y|). Obviously, I could't get the phase from this data which I need. The output data type of the waveform should be Impedance, but it actually outputs Rectangular type. How can I get the data I need from this srrWave?
