  2. RF Design
  3. Spectre netlist defining voltage gain and saving the results...
  • Subscribers 62
  • Views 2872
Spectre netlist defining voltage gain and saving the results to view in the psf file
GM202510215619
GM202510215619 4 months ago
Hello, I have a simple circuit with Vout as the output node of the amplifier and Vin as the input node of the amplifier.
I want to save the dB voltage gain results and plot it in ViVA from the raw file.
Is there a way to do it through using a few lines of code in my spectre testbench netlist?
Any help would be appreciated. Thank you
-GGM
    Andrew Beckett 4 months ago
    If you want small-signal gain, you could use an xf analysis:
    xf (Vout 0) xf start=1 stop=1G
    Then in the xf results, you'll see listed all the voltage sources in the circuit. Assuming there's one which is connected to the Vin signal, you can set the results browser to plot in dB20 (it will show Default and Magnitude at the top of the results browser; change the Magnitude to dB20). Double click on the voltage source and you'll get the gain in dB.
  • GM202510215619
    GM202510215619 4 months ago in reply to Andrew Beckett
    Is this also the way to do it for differential nodes?
    Andrew Beckett 4 months ago in reply to GM202510215619
    The output of an xf analysis can certainly be differential. If the input is a single voltage source (across a differential input, biased somehow) then you could use xf analysis. Or you could use ac analysis and have two input sources each with (say) mag=0.5 (phase set appropriate or one source inverted) and then plot the output voltage in the ac results between the two output nodes.
  • GM202510215619
    Thanks so much for the quick answers. I was able to get the transfer gain using both methods. I was wondering if there's a way to save differential voltage without using calc in ViVA. The method I am using now is something like:
    VpOUT (OUT 0) bsource v=v(OUTP, OUTN)
    Then node OUT is saved as differential voltage.
    I might be missing a simple way to do the same.
    Or simpler still:
    VpOUT (OUT 0 OUTP OUTN) vcvs gain=1
    Note that ViVA can also plot differential signals without needing to use the calculator.
